Transparent material, which will be both scratch-proof and break-proof?
Hello.
I have certain electronic gift idea, for which I need to have custom front panel, which will be transparent - to allow leds to see trough, and to be scratch proof (from daily abuse, nothing specific) and drop proof at same time. I've searched a lot but, nothing good comes up.
Even the "scratch-proof" lexan is actually quite scratchy. But provides nice resistane to drops, hits, etc. Tempered glass has excellent scratch-proof characteristics, but is very prone to shattering. I've heard once, that there's special material, in which, ultra thin layer of glass is adhered to polycarbonate base, so it works nicely against drops and scratches. But I forgotten the name, maybe anyone remembers?
http://nameplatesforindustry.com/faceplates-overlays/
For prototyping, I would work with one side mar resistant polycarb, refine the back side silk screen process, and see if you can work with that for a while. Machining the glass is a beast to master and get set up for, and forget finding someone to make glass panels for you with nice edge detail, only a cnc will route and bevel small panels since the larger machines require typically a 12" side for polishing. If the edges can be hidden under a material, glass becomes very simple to use. But if the edges must be exposed and look nice, that is a big investment to tackle.
I'm not sure if they sell it in small lots.
You can have clear and translucent types.
A fablab or similar close could help printing them. If the parts are small/thin they can be reasonably cheap.
You could also couple laser cut wood with small 3d printed clear inserts to keep cost low...
Massimo
Acrylite Resist 65
Polycarbonate Abrasive Resistant
They sell 4" x 4" samples for $2.
Finding someone to do the coating could be a trick, unless you know someone that works at an optics outfit. Some optometrists have the equipment in their offices, or they farm it out to a local business. Otherwise you start getting into some real money going to a specialty industrial source that can be quite costly.
Ahem, silicon not silicone... unless there is a type of silicone that I am not aware of. Not that there aren't thing that I am not aware of, I am sure there are many...
http://www.exxene.com/core-products/hardcoats/
I am so confused. I found another place that talks about hard silicone. Seems like an oxymoron to me. How can silicone be hard???
The polycarb Duane noted might also do the trick, though I'm not familiar with the properties of the 3M coating used:
http://www.tapplastics.com/product/plastics/cut_to_size_plastic/polycarbonate_sheets_ar/517
The Tap page has a spec sheet showing the abrasion resistance is just slightly less than tempered glass, but far more impact resistant than glass. A 4" square sample only costs $2. Worth a shot.
Machining glass requires 100% flood at the cutting tool contacting the glass. Even 1 second without flood and the tool melts.
Here is the router I used, it will cut the glass and put a bevel if you need it.
http://www.crlaurence.com/crlapps/showline/offerpage.aspx?Productid=11890&GroupID=5763&History=39324:386:5739:5758&ModelID=5763
http://www.crlaurence.com/crlapps/showline/offerpage.aspx?ProductID=2880&GroupID=1581&History=39324:1220:1551:1554&ModelID=1581&pom=0
When its a cross-linked polymer I expect. That's the difference between silicone oils and silicone resins I think. Adding silica
nano-particles might be possible I'd have thought.
The ultimate abrasion resistance tough glass is sapphire glass (Al2O3), used in expensive watches/phones I believe. Not cheap.
If you find a suitable substrate that does what you're calling for be sure to tell Apple, Samsung, and all the other cell phone makers. They'll want to know about it!
http://en.wikipedia.org/wiki/Transparent_aluminum#Transparent_aluminum
They still will break. They just won't shatter into pieces of sharp glass in someone's back pocket.
If the transparent material has to survive keys in someone's pocket, I think a Saphire wafer or window is one of the few things that will survive. Should be able to score and crack a wafer to size, then finish with diamond abrasives. Might also see if you can get a Diamond Like Coating (DLC) on tempered glass. If the DLC is thick enough, it should be (nearly) impervious to scratches. (point contact stresses are highest just under the surface. If the hard coating doesn't extend past this zone, it won't prevent scratches well. I.e. Aluminum Vs Hard-anodized Aluminum)
Marty
Since it needs machined to specific shape, and phone screens/cases are multi-layer/multi-process devices, attemt to machine them causes jaggy edges, separated layers and other unusable results.
