Chameleon and SimpleIDE on MacOSX — Parallax Forums
dossicdossic Posts: 38
edited 2013-12-08 22:45 in Propeller 1
Dear friends,
I have a Chameleon bord I'm very satisfied with. Until recently, I used Propeller Tool and SimpleIDE on Windows to program it (on Propeller side, obviously). Few weeks ago, I moved to a MacBook Air computer, I abandoned Propeller Tool, and I started woking on SimpleIDE on Mac. Mac and SimpleIDE recognizes the Chameleon board (after downloading and installing FTDI drivers), but Propeller-Load can't see it :
propeller-load -S5 -Dreset=dtr -r Amel2559_Firmware ver 120r1.binary -p /dev/cu.usbserial-A800edo7
error: no propeller chip on port '/dev/cu.usbserial-A800edo7'
(p.s. the port is actually that seen on Mac using ls /dev/tty.* on Terminal)
I tried setting delay to 1 thru 50, but nothing changed. When I come back to Windows, downloading is OK again.
Can you please suggest me a possible solution?
Greetings from Lake Como
carlo
  • David BetzDavid Betz Posts: 14,516
    edited 2013-12-08 11:34
    dossic wrote: »
    Dear friends,
    carlo
    propeller-load should automatically detect the port if you leave off the -p option. Also, it looks like you're using a filename with spaces in it. You'll need to put quotes around that so that propeller-load doesn't think it is several arguments.
  • dossicdossic Posts: 38
    edited 2013-12-08 13:49
    David Betz wrote: »
    Hi! Thanks for the reply!
    Actually, I wasn't using propeller-load on terminal, but the message appeared on SimpleIDE when trying to compile the file (alt+F11 on Mac). I tried with a new filename without spaces, but no changes. It doesn't find any propeller on the USB port.
    I'll try again, and I'll keep you informed.
    Yours Carlo
  • jazzedjazzed Posts: 11,803
    edited 2013-12-08 14:23
    dossic wrote: »
    Yours Carlo
    What kind of a board are you using Carlo?
    I suspect there is some kind of a reset problem or serial communications problem. Do you see any LED blinking during the load attempt?
    You shouldn't need to have loader-delay set at all (-S1 reflects Properties->General->Loader Delay as 1).
    --Steve
    edited 2013-12-08 17:25
    dossic wrote: »
    Yours Carlo
    Are you sure you have the programming jumper set to select the Propeller rather than the AVR/PIC? Which Chameleon do you have? I have both the AVR and the PIC board so I can try to duplicate your problem. I don''t think we've ever tried any of our tools on the Chameleons but I don't see why they wouldn't work together.
    David Betz wrote: »
    Hi David!
    My board is the Chameleon AVR, sorry for forgetting to specify it in my previous post.
    Then I did a bunch of experiment, I'm summarizing here.
    1.Switch was always selected to allow USB to talk to the Propeller.
    2. My Chameleon-AVR board is working properly with SimpleIDE in Windows (emulated in VirtualBox).! Tried again with SimpleIDE on Mac, no luck, Propeller chip wasn't found.
    3. Then I connected my old demo board to SimpleIDE on Mac;everything worked fine.
    So, apparently my Chameleon doesn't like the Mac!!! Thanks for helping me to find a solution.
    Carlo
