Constant Navigation
Hi, I am taking data from GPS using Arduino Uno. GPS's model is PMB-688 and i am using an external antenna(This is not the antenna that is in here:"http://www.parallax.com/product/28502" I am using an another antenna but it is working.) When i started to walk, i cannot take different data between each 30-40 meters. What do you think about whether it is an unexpected situation? In the datasheet of this product it is written that accuracy is about 5 meters. (http://www.parallax.com/sites/default/files/downloads/28501-PMB-688-v0.1.pdf)
These are explained in here: http://learn.parallax.com/project/constant-navigation-gps What do you think about whether it can be a solution to overcome my problem. In that website it is not explained for Arduino. I don't use Propeller Board of Education. Do you have any idea about how i can change it to Constant Navigation? Is there any disadvantage when i change it? I am trying calculating distance between points which i walked and this is my code. Thank you so much.
The duplicate post in General has been removed:
http://forums.parallax.com/showthread.php/134682-Forum-Guidelines
Particularly this thread.
