Help a PASM noob...
Hello everyone,
Here is my first real attempt at PASM. Of course, it did not turn out to be working...
The aim is to listen an RF module which outputs data at 9600 bauds. The protocol is serial, but homemade to filter the RF noise.
The same approach worked in SPIN, but I just needed extra ticks to process the data in a more efficient way between two frames.
The emitter will first emit some random bits to set the gain of the RF receiver so noise is less a problem.
Then it sends three bytes in that order:
- first an header (to confirm this is the data we want to receive)
- the data byte
- and again the same data byte (I'll change that to a proper checksum when I get it working...)
Here is the code:
Somehow, I never get more than one high bit in RxBuf, even though I keep outputing data on the RF, and the scope confirms the data is received...
If you have any inputs, ideas, fixes, you're all very welcome. I won't be offended if you say it's badly coded, it truly is my first PASM code (well the 2nd, the first one being a "flashing LED hello world"...)
Best regards,
Jean Luc
- the data byte
Here is the code:
DAT org 0 entry mov RCVpin,#0 'RCVpin is 0, hardcoded for now mov dRCVpin,#1 'decode RCVpin to... shl dRCVpin,RCVpin '...binary format rdlong x,#0 'get CLKFREQ mov y,baud 'sets y to divide clockfreq by baud call #divide 'clockfreq/baud shl x,#16 'we need to get only x[0..15] for... shr x,#16 '...the result mov BitTime,x 'bittime=clokfreq/baud mov rxbyte,#0 'reset rxbyte mov halfBitTime,BitTime 'computing... shr halfBitTime,#1 ' ...halfBitTime mov rxbuf,#0 wz 'reset rxbuf, and set Z flag to 1 at the same time for the muxnz muxnz dira,dRCVpin 'we must set only the drcvpin to input=>low Sync mov rxbuf,#0 'reset rxbuf :loop waitpeq dRCVpin,dRCVpin 'wait for RCVpin to be High mov t,cnt 'init time reference mov x,#0 'waitPEQ pattern all to LOW waitpeq x,dRCVpin 'wait for RCVpin to be Low sub t,cnt 't=t-cnt cmp t,halfBitTime wc 'if t<bittime/2 then it's noise,and C flag is set to 1 if_c jmp #:loop mov t,cnt add t,halfBitTime add t,BitTime getbyte waitcnt t,BitTime 'wait for middle of bit shl rxbuf,#1 'shift rxbuf left by one bit test ina,dRCVpin wz muxnz rxbuf,#1 'if INA & dRCVpin<>0 we put a 1 in the LSB of rxbuf mov y,rxbuf and y,sel_HDR cmp y,HDR wz 'if byteN°3 is the hdr byte we set Z flag to 1 if_nz jmp #getbyte 'if no HDR byte we jump back to read a new bit from RXpin mov byt,rxbuf 'put rxbuff in byt shr byt,#8 'we remove the trailer byte and byt,#$FF 'and also the header byte, so byt is a potential RxByte mov y,rxbuf and y,Trail_byte cmp y,Trail_byte wz 'if byt equals trail byte, we set Z flag to 1 if_nz jmp #getbyte 'if not, we go grab a new bit mov rxbyte,byt 'so we got a correct RxByte! jmp #Sync 'and we're happy to try again! 'divide routine by parallax: 'divide x[31.00] by y[15..0] (y[16] must be 0) 'on exit, quotient is i x[15..0] and remainder is in x[31.16] divide shl y,#15 mov t,#16 :loop cmpsub x,y wc rcl x,#1 djnz t,#:loop divide_ret ret sel_HDR long %11111111_00000000_00000000 HDR long %01010101_00000000_00000000 Trail_byte long %00000000_00000000_11111111 Data_byte long %00000000_11111111_00000000 baud long 9600 RCVpin long 0 dRCVpin res 1 BitTime res 1 halfBitTime res 1 x res 1 y res 1 rxbyte res 1 byt res 1 rxbuf res 1 t res 1 trail res 1 fit 496
Best regards,
Jean Luc
One question regarding the test instruction, why would the order of operands matter in this particular case?
Thanks a lot!
