800x600 VGA
Hi all, first post :-)
Im trying to sift my way through vgademo that comes with SimpleIDE, in order to create 800x600 VGA @ 60Hz (its the only thing my monitor will recognize).
I tried simply changing ncol and nrow under draw.c to 800 and 600, respectively, but to no avail. Can anyone help?
Thanks!
Thanks!
zip
65K
Are you sure ? - Most PCs early boot messages come at a lower resolution - does your monitor show those ?
With monitor issues, it can be good to get something working, then move from there.
http://forums.parallax.com/showthread.php/140170-VGA-20-column-driver?p=1099207&highlight=800x600+timing#post1099207
I also found another post bykuroneko that looks useful. Between the two I think I should be able to get things running.
http://forums.parallax.com/showthread.php/135844-POC-most-useless-piece-of-code-ever-The
Cool, as you have probably guessed, Kuroneko is something of a wizard at this.
