parallax laser range finder #28044
hello,
am new to programming and am doing a project that am required to use a parallax laser range finder to detect an object and measure its distance. I want to use arduino to do this. am connecting the SIN pin of the sensor to analog pin 2 and SOUT to analog pin3. Then am using the code by Roy Eltham, the problem is there is no response from either the sensor, the arduino or the LCD display. where am I going wrong? could it be the connection with arduino or the sensor is not working?.please assist. Here is the code
Simple LRF Demo
by Roy Eltham and Dino Segovis
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// include the SoftwareSerial library so we can use it to talk to the LRF
#include <SoftwareSerial.h>
#define rxPin 8 // connect to the LRF's SOUT pin
#define txPin 9 // connect to the LRF's SIN pin thru a 4.7k resister
// set up a new serial port
SoftwareSerial lrfSerial = SoftwareSerial(rxPin, txPin);
void setup()
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// define pin modes for tx, rx, led pins:
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
// set the data rate for the SoftwareSerial port
lrfSerial.begin(9600);
// send a U to the LRF so that it will autodetect the speed to communicate with us at (9600)
lrfSerial.print('U');
// the LRF will send back a : and a newline, we just read and ignore those here
lrfSerial.read();
lrfSerial.read();
//print splash screen
lcd.print("Laser");
lcd.setCursor(0, 1);
lcd.print(" Range");
delay(3000);
lcd.clear();
// send a E to the LRF to adjust camera to current lighting conditions
// lrfSerial.print('E');
// delay(1000);
//tell the user that the LRF is ready
lcd.print("LRF ready.");
delay(1500);
lcd.clear();
// Print a message to the LCD.
lcd.print("Distance in mm");
void loop()
// send an R to the LRF telling it to take a measurement
lrfSerial.print('R');
// read what the LRF sends back
char lrfData[32];
int offset = 0;
lrfData[0] = 0;
while(1)
lrfData[offset] = lrfSerial.read();
// if we get a : character that indicates the end of the read data (and that the LRF is ready for the next command)
if (lrfData[offset] == ':')
lrfData[offset] = 0; // null terminate the string of bytes and break out of the loop
break;
offset++;
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
// print out the data from the LRF (it sends back a string in the form "D = xxxx mm" where xxxx is the distance in milimeters
lcd.print(lrfData);
// delay a tiny bit before the next read
delay(100);
//integer to convert lrfData string to an integer value
int distance = atoi(&lrfData[4]);
//sound the alert if the distance is less than one meter
if (distance < 1000)
tone(5, 440, 200);
delay(200);
Simple LRF Demo
void setup()
lcd.begin(16, 2);
lrfSerial.read();
lrfSerial.read();
lcd.print("Laser");
delay(3000);
lcd.clear();
// delay(1000);
delay(1500);
lcd.clear();
void loop()
char lrfData[32];
int offset = 0;
lrfData[0] = 0;
while(1)
break;
offset++;
lcd.print(lrfData);
delay(100);
tone(5, 440, 200);
delay(200);
Simple LRF Demo
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
#define rxPin 2 // connect to the LRF's SOUT pin
#define txPin 3 // connect to the LRF's SIN pin thru a 4.7k resister
void setup()
lcd.begin(16, 4);
lrfSerial.read();
lrfSerial.read();
lcd.print("Laser");
lcd.setCursor(0, 2);
lcd.print(" Finder");
delay(3000);
lcd.clear();
// delay(1000);
delay(1500);
lcd.clear();
void loop()
char lrfData[32];
int offset = 0;
lrfData[0] = 0;
while(1)
break;
offset++;
lcd.print(lrfData);
delay(100);
tone(5, 440, 200);
delay(200);
