Best way to fix possible Xbee Pro Line of Issues
I'm in the planning stages in setting up Xbee Pro's to be setup in "Line Passing" mode to control and monitor our signal system at the Baltimore Streetcar Museum (Trolley Car museum).
The problem is that the Xbee Pro's that was thinking of using will not be in a direct line of sight of the other Xbee Pro that will be 1/2 mile away from the other Xbee Pro due to a slight curve in our trolley line and also our shop building that is at the beginning of this curve will make the two Xbee's not being in direct line of sight of other.
One of the ways I was thinking of fixing this issue, was using 1 or 2 Xbee Pro's to be used as repeaters setup on the roof of the shop building to help with the line of sight issue and I wanted to know is this the best way to fix this issue.
Either way, I'm sure it's possible (you might need a microcontroller to configure the middle XBee).
What version of XBees do you have? What are you using to communicate with the XBees.
Another option would be the 900MHz long range version of the XBee. It still requires line of sight though and the signal may still be blocked my the buildings.
That is what I'm hoping for. That would mean I need 3 XBee Pro with good antennas on them. But, I don't know if router part will work in "Line Passing" mode.
To help you all understand location of the museum trolley line here's a link to Google maps<iframe width="425" height="350" frameborder="0" scrolling="no" marginheight="0" marginwidth="0" src="https://maps.google.com/maps?f=q&source=s_q&hl=en&geocode=&q=Baltimore+Streetcar+Museum+Streetcar+Rides,+Maryland+25,+Baltimore,+MD&aq=1&oq=baltimore+streetc&sll=38.728376,-77.34375&sspn=4.644844,7.064209&t=h&ie=UTF8&hq=&hnear=Baltimore+Streetcar+Museum+Streetcar+Rides,+Maryland+25,+Baltimore,+Maryland+21211&ll=39.31232,-76.620712&spn=0.023243,0.036478&z=14&iwloc=A&output=embed"></iframe><br /><small><a href="https://maps.google.com/maps?f=q&source=embed&hl=en&geocode=&q=Baltimore+Streetcar+Museum+Streetcar+Rides,+Maryland+25,+Baltimore,+MD&aq=1&oq=baltimore+streetc&sll=38.728376,-77.34375&sspn=4.644844,7.064209&t=h&ie=UTF8&hq=&hnear=Baltimore+Streetcar+Museum+Streetcar+Rides,+Maryland+25,+Baltimore,+Maryland+21211&ll=39.31232,-76.620712&spn=0.023243,0.036478&z=14&iwloc=A" style="color:#0000FF;text-align:left">View Larger Map</a></small>
The visitor center would be one XBee location (microcontroller location), shop building midway up the line for a router XBee and the signal location about 5 poles up the line from the shop near the switch before going to single track.
The only Digi modules that have "line passing" per se are the XB24 and XBP24 802.15.4 series 1. Line passing allows two XBees to work together without any other microcontroller, so that digital inputs on one come out as digital outputs on a remote, and analog inputs on one come out as PWM on a remote. Strict limits on what it can do. Series 1 modules do not have much repeater capability, however, you can achieve one hop by enabling one device in the middle as a coordinator. It is a bit harder than peer-to-peer to set up.
Other Digi modules do not have "line passing" but they do have "line monitoring" or "line sampling". A remote XBee can acquire and transmit digital and analog data periodically or on change of state, without needing a micro attached, but the receiver on the other end does need a micro to read the data. No automatic binding of pins. That applies to the XBP09 (900MHz) modules, and to the series 2 XBee ZB (Zigbee) modules, and to the Digimesh modules.
I was planning on using the Propeller to be attached at one end anyway for controlling the signal states.
One of the big problem for the "line of sight" issue is not much the curve in our line its the hill that forms the curve that the line follows. Will directional antennas do any good or is it better "hop" to the other building instead?
I think you'll just have to try to see how far it will go once you have the radios. Use the XCTU or some other range test program that monitors the error rate as you walk it away. 900MHz would probably fare better than 2.4GHz. Radio propagation can be funny. Even if you get it working one day, success may also depend on weather and how many others around are using the channels, etc. Indeed, the most reliable would probably be more hops to bring it around the hill.
