P2 2D/3D Internal Working Model?
                    I always get a lot out of seeing a 2D or 3D model.  Would anyone benefit from seeing the basic internal processes(data flow)?  The Prop 1 had a very simple graphic with the gear illustrating the 8 cogs plus hub.  I am thinking of something on another level, possibly animated in the future. What is this best done in?  Solidworks would work but is pricey and has a learning curve.  I can whip up non animated stuff in CAD.  For my own purposes I would like to do something as a starting point and see if there is any public merit.  If anyone thinks this has value, especially for newbies, what would be the basics to illustrate?
Examples:
1. show 8 cog engines in a circular shape.
2. show cyclic access to hub
3. show cog interaction/path to all pins
                            Examples:
https://github.com/mbostock/d3/wiki/Gallery
But that's not a trivial task...
http://lib.ivank.net/
Or go full 3D with webgl using the three,js library. Also very easy to use.
http://threejs.org/
Yeah, yeah, IE does not support webgl. So what?
