BOE-BOT - serial or USB?
I am currently planning to buy a BOE-BOT for my nephew for Christmas. I would like to know if there is any advantage or disadvantage to purchasing the serial BOE-BOT with the serial to USB adapter rather than the BOE-BOT USB kit.
Are there any accessories that would work only with a serial port and not with a USB port?
Are there any problems with using the serial + USB adapter that do not occur with the USB only model?
Thanks for your help
Tom
Tom
That being said, have you looked at the newer ActivityBot from Parallax? It's on sale today, and it has many more features.
Thanks again
Tom
Parallax has been working hard on making C as easy as possible to get into. They have all their learn material here. After the cost of the hardware there is nothing left to purchase: it's all open source.
As for whether or not it's something that he can handle others will be able to answer better. I've worked with some 8th graders on C before, and they seemed to get it well enough (as long as it was initially set up for them).
Yes, in some ways the USB port is a more limited communication format, but there are other i/o pins that can be use for RS232 serial with any BOE-Bot (the BS2 or the Propeller).
My personal leaning is against USB, but kids want to get off to a fast start.
Parallax provides the C compiler at no extra charge, and there are other languages as well --- Basic, Spin, Java, Forth, and so on. More than enough to get started. Try the Parallax LEARN website for the best beginner support.
