SD card reading and writing?
I am trying to learn to write and read a SD Card.I am using the Object package -fsrw-andifriends-1.7(Attached to this post)
Iam trying to under stand the code in the - sdrw -VGA Demo.
In this the PUB start - has the following code :
pub start | r, sta, bytes
term.start(16, @array, @vgacolours, @cursor_x, 0, 0)
print($100)
ps(string("Mounting.", 13))
sd.mount(0)
ps(string("Mounted.", 13))
ps(string("Dir: ", 13))
sd.opendir
repeat while 0 == sd.nextfile(@tbuf)
ps(@tbuf)
What I dont understang is the code lines " ps(string("Mounting",13)
I under stand what it does but I do not understand the reference "ps"
When code reference to an oblect - sd.opendir - I know it refers to the Pub in the object "Term"
But there is no Oblect labelled "ps"
Please explain this reference so I will understand the code.
Thank you,
Siri
print($100)
sd.mount(0)
sd.opendir
ps(@tbuf)
Thank you,
Siri
Thank you very much.I was going through the PUB methods and NOT the PRI methods. As PRI are not referenced in the objects.
Thanks again
Siri
