Trouble understanding CTRMODE modes in CTRA and CTRB
MJHanagan
I am having difficulty interpreting some PASM code from the OBEX object "jm_sircs_rx.spin". In the "mov ctra, NEG_DETECT" instruction it uses a CTRMODE value of %01100 (NEG detector) with no pin value specified. From this I assume that every internal clock tick increments the phsa register by 1. In essence this becomes an alternative CNT register which is user reset by writing a value of 0 to phsa (as is done in the code below).
The "mov ctrb, FREE_RUN" instruction uses a CTRMODE value of %11111 (LOGIC always) with no pin specified. From page 14 in the "AN001 Propeller P8X32A Counters" this seems to also act as a simple resetable CNT counter incrementing the phsb register by 1 with each clock tick.
My question is: how does CTRA differ from CTRB?
dat org 0 rxsircs mov ctra, NEG_DETECT ' set ctra for pulse timing mov frqa, #1 mov ctrb, FREE_RUN ' set ctrb for frame timing mov frqb, #1 waitok rdlong tmp1, okpntr wz ' wait for zero (FALSE). if_nz jmp #waitok waitstart waitpeq irmask, irmask ' wait for high mov phsa, #0 ' start bit timer waitpne irmask, irmask ' wait for low mov phsb, #0 ' start frame timer waitpeq irmask, irmask ' wait for high cmp START_BIT, phsa wc ' valid start bit? if_nc jmp #waitstart ' try again if no mov irwork, #0 mov bits, #0 ' reset bit count checkframe cmp MS_044, phsb wc ' check frame timer if_c jmp #irdone ' abort @44ms waitbit test irmask, ina wz ' look for new bit if_nz jmp #checkframe ' check for end if no bit measurebit mov phsa, #0 ' resstart bit timer waitpeq irmask, irmask ' wait for high (end of bit) cmp ONE_BIT, phsa wc ' ir bit --> C rcr irwork, #1 ' C --> irwork.31 add bits, #1 ' inc bit count cmp bits, #20 wc ' at max? if_b jmp #checkframe ' keep scanning if no irdone mov tmp1, #32 sub tmp1, bits shr irwork, tmp1 ' right align ir code report wrlong irwork, codepntr ' write code to hub wrlong bits, bitspntr ' write bit count to hub wrlong DONE, okpntr ' alert caller jmp #waitok ' ------------------------------------------------------------------------------------------------- DONE long true NEG_DETECT long %01100 << 26 ' ctr neg detector FREE_RUN long %11111 << 26 ' ctr logic always mode START_BIT long 0-0 ' counts in 80% of 2.4ms ONE_BIT long 0-0 ' counts in 80% of 1.2ms MS_044 long 0-0 ' counts in 44ms irmask long 0-0 ' pin mask for ir input okpntr long 0-0 ' pointer to ready flag codepntr long 0-0 ' pointer to ir code bitspntr long 0-0 ' pointer to bit count of code irwork res 1 ' workspace for ir input bits res 1 ' # bits in input tmp1 res 1 tmp2 res 1 fit 492
It seems like in the case of ctra the input pin needs to be specified, but I cannot find where this is done. In my setup the IR input signal pin is 26. Since NEG_DETECT is defined as "long %01100 << 26" the lower bits 0-5 are zeros, therefore no pin specified.
Just had a look at the code, either the NEG_DETECT mode is intended - then the pin setup is missing otherwise pin #0 being high would block ctra - or it's supposed to be the same as ctrb. Not sure about the latter, I'd have to check the protocol first.
Update: My vote goes to missing setup. A NEG_DETECT.byte{0} := p in the init method should take care of that (untested).
I'm using a QuickStart board and don't think I am actively using pin 0 so it might indeed be low so it works. I will try adding the pin value in the init as you suggested and try it.
Thank you for the help.
