design firing circuit for thyristor
The supply is 220v 50Hz ac.I need 60V DC output voltage .For this i need to fire the thyristor at 80
degree.The main problem is to fire the thyristor at 80 degree .please sugest me the firing circuit.
for half wave controlled rectifier
Vdc=Vm(1+cost)/2*pi
here t=firing angle
Vm=maximum ac voltage
Vdc=output DC voltage
So for Vdc=60V ,Vm=1.414*220=311
t=?
the required firing angle would be 80 degree.
so please help me how i can fire the scr at an angle 80 degree.
Vdc=Vm(1+cost)/2*pi
here t=firing angle
t=?
If you use a PS2505L-1-A Transistor Output Optocoupler (for mains hertz detection) with a 10k Pull-up, the line goes high for a short duration around +-5deg
Use 100K instead of 47K resistor with 220v
http://forums.parallax.com/showthread.php/149577-Dual-SSR-inside-a-PowerStrip?p=1220544&viewfull=1#post1220544
this devise can do 50v DC @100mA (bonus 3.3v out)
http://www.mouser.com/ProductDetail/Supertex/SR086SG-G/?qs=sGAEpiMZZMtitjHzVIkrqRqycvdJ8kbVcrhZveqCdEk%3d
and the LR12
http://www.mouser.com/Supertex/Semiconductors/Power-Management-ICs/Voltage-Regulators-Standard/_/N-5cg9g?P=1z12mu3Z1z0jbza
