Gyroscope 3 axis accuracy help
I just purchased a Gyroscope Module 3-Axis L3G4200D for my school project and I was trying to find what +/- degrees it starts to work at. I am guessing that it should be less than 5 degrees but I cant seem to find it in the data sheets anywhere. For example some tilt sensors works when the sensor are tilted at +/- 45 degrees or operate at +/- 45 degree like http://www.digikey.com/product-detail/en/TM1000Q/EG4917TR-ND/2541277 . I cant seem to find the accuracy/operating angle for the 3-axis Gyroscope from the data sheet , documentation, or from http://www.st.com/st-web-ui/static/active/en/resource/technical/document/technical_article/DM00034730.pdf . I am not sure if i need to convert something to find the operating angle?
Any help will be appreciated. Thank you.
