SMBus question
TC
Hello All,
Has anyone used SMBus with the Propeller? I know it is similar to I2C but not quite. What would be my best option on getting it to work with the Prop?
TC
TC
SMB is essentially a super-set of I2C.
The physical and link layers are identical IIRC.
Network protocol layers formalize error handling and transfer methodology like multiple byte read/write, etc....
What aspect of SMB do you need that I2C doesn't provide?
I just dont know anything about it (or I2C), and I was just wondering if anyone had some experience with it, and what method they used.
http://www.maximintegrated.com/app-notes/index.mvp/id/476
You could simply try it with an I2C driver.
If it does not work the timing diagrams in the SMBus specs and a COG recording the signals can help to find the problem.
I was thinking the same thing. I think I will just have to get the part, and see what happens. worst case, I will be back on here looking for help.
I might just take you up on that offer after I get the chip. Thank You
