Problem with servo code — Parallax Forums
jmerrelljmerrell Posts: 25
edited 2013-11-21 12:33 in General Discussion
Solution found.
  • Beau SchwabeBeau Schwabe Posts: 6,568
    edited 2013-11-20 22:18
    Please elaborate what your solution was so that others can benefit from your findings.
  • jmerrelljmerrell Posts: 25
    edited 2013-11-21 10:57
    My servo was not rotating properly, and sometimes not at all when IN1 went HIGH. I had 2 servos connected to the servo ports P14 and P15 and at the same time was utilizing P8-P15 for a 7-segment display. What a rookie mistake! I should have known better. So I moved the display and assiciated wiring to P0-P7 and everything works as it should, even the counter (as seen in my earlier post, "Score counter from 0-3" dated 11-16-2013). The suggestions I received on the forum made sense but I could not get it to work. It's mistakes like this one that one never forgets. I have also implemented some of the past suggestions into my program. Thanks everyone.
    jmerrell wrote: »
    Thanks for sharing that!
    You don't know how sharing that bit of info will help many others in the future.
