power supply help!
i have a robotic arm which is controlled by a bs2 processor. the power supply is the standard 4AA batteries 1,2 volts 2500mamps. when i lift lightweight stuff such as small sponges and a AA battery things are ok. when i try to lift heavy things such as a servo it crashes and restarts the whole process from the start. i tried to power it from a power supply that has 16 volts and 4amps. it can lift very heavy objects but it goes very funny. it shakes and vibrates and i think it is going to explode or brake into thousand pieces...
can anyone tell me what power supply i must use in order to lift heavy loads but also run smooth? there are 5 motors, 2 connected with the same line bottom servos, and most of the times there are 3 servos working ( 2 connected as one, and another one).
if i use a 7,5v and 1 amp plug power supply will it have the ability to lift heavy loads?
for the record i have switched the pin from Vin to Vdd and works smoother but loses the ability to transfer heavy loads from a point A to point B. still does better than the 4 AA battery.
thank you in advance!
"Personally, I would either use two battery packs, one for the BS2 and any digital circuitry (sensors, etc.) and one larger one for the servos." connecting one battery pack on the board and the other at the positive of the servos?
thank you for your answer!
A 12V power supply will damage the servos and may cause the BS2 to overheat. Servos are designed to work with a voltage between 4.8V and 7.2V. The BS2, although it will work with a Vin of up to 9V, really works best (from a heat dissipation standpoint) from 6V to 7.2V, similarly for the Board of Education. Both the BS2 and the Board of Education should work with a 12V supply, but the regulators will produce a lot of heat and may shut down to protect themselves if they get too hot.
