Arduino BoeBot-Left Wheel Wont go Backwards — Parallax Forums
surfcrssurfcrs Posts: 4
edited 2013-11-20 18:41 in Robotics
Hi everybody, just finished assembling Arduino Boe Bot and trying out a few basic commands. It seems that after trying out a few sketches that The robot left wheel simply won't ever go backwards. Forward fine, Right Wheel forward and backward both fine, but no reverse on left side...any ideas where to check next? Thanks
    edited 2013-11-16 23:52
    Swap your servo connectors to see if the problem is the board output or the servo.
    edited 2013-11-17 04:05
    Make sure that you have run the center adjustment for both wheels. I've seen this cause a servo to only turn one direction.
  • surfcrssurfcrs Posts: 4
    edited 2013-11-18 14:02
    Thanks for those replies. It was the servo centering. I I think I copied the wrong sketch when calibrating that wheel, all seems to working now. Thanks again.
    edited 2013-11-18 19:14
    You're welcome! Enjoy your Boe-bot, they're great fun.
  • NWCCTVNWCCTV Posts: 3,629
    Well, it is an Ar%*^#@
