Get array length?
Is there a way to get an array length, maybe by how many array indexes are set? Some values will be 0 including the first and last values.
variable[0] := 0 variable[1] := 54 variable[2] := 15300 variable[3] := 0 variable[4] := 1 variable[5] := 0
Wouldn't it be easier to keep track of the index as the array is filled?
Have you seen this thread? You can backup variables to their original locations in EEPROM so next time RAM is loaded from EEPROM the variable values get restored to the values of the previous session.
Here is a demo.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 CON MAX_ARRAY = 10 VAR long array[MAX_ARRAY] byte arrayIdx OBJ pst : "Parallax Serial Terminal" PUB Main | i pst.Start(115_200) pause(1000) 'Initialize array index counter arrayIdx := 0 pst.str(string("Array Length Demo", 13, "------------------------", 13)) array[arrayIdx++] := 0 array[arrayIdx++] := 54 array[arrayIdx++] := 15300 array[arrayIdx++] := 0 array[arrayIdx++] := 1 array[arrayIdx++] := 0 pst.str(string("Array Length: ")) pst.dec(arrayIdx) pst.char(13) repeat i from 0 to arrayIdx - 1 pst.str(string("array[")) pst.dec(i) pst.str(string("] = ")) pst.dec(array[i]) pst.char(13) PRI pause(Duration) waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt) return
