Ping my LED
Hello all. I am alittle stuck trying to get my LED on pin 7 to turn on when my ping senser is reading < than '90, and turn off when => '90.
{{ ┌─────────────────────────────────────┬────────────────┬─────────────────────┬───────────────┐ │ dualPing Demo │ BR │ (C)2008 │ 13Sept09 │ ├─────────────────────────────────────┴────────────────┴─────────────────────┴───────────────┤ │ │ │ Update/extension of the original Savage/Martin object. │ │ This object is a dual-channel driver for Ping))) ultrasonic ranging units (Channels A & B).│ │ A single cog is used to monitor both ping units (via counters A & B). │ │ │ │ Features: •counters used for time-of-flight measurement (fire & forget) │ │ •dual ping driver capable of 2 simultaneous measurements │ │ •simple ambient temperature compensation functionality │ │ •drop-in replacement for original object │ │ │ │ Miscellaneous notes: │ │ •Although this object can drive 2 Ping))) units, it works perfectly fine for single │ │ channel applications, too...just leave the AorB selector set to A and use channel A. │ │ •If you are using two Ping))) units simultaneously, there is significant possibility │ │ for mutual interference. To avoid this, it is recommended that the two Ping))) units │ │ be placed AT LEAST a foot apart and that each be angled at least 15-20 deg out from each │ │ other. │ │ •It is strongly recommended that the Ping))) units be mounted inside small open-ended │ │ boxes (like project boxes, for example) to help isolate them from noise. Why? │ │ A room is typically a confined space filled with many hard surfaces and lots of good │ │ sound reflectors that tend to accentuate noise. In addition, the Ping))) unit apparently │ │ has significant ringdown and/or sidelobes that can add to this interference. As such, │ │ it can sometimes be difficult to get consistent/reliable range measurements. A box helps │ │ to: a) block extraneous ambeint noise b) channel energy coming from sidelobes out toward │ │ the front of the sensor where it does no harm, and c) adds directivity to the reciever. │ │ For example: the back wall of my garage is made of cinder blocks. If the bare Ping))) │ │ unit is placed against this wall facing out into the garage, I cannot get a correct range │ │ measurement as long as the Ping))) unit is within about 8" or less of this block wall, │ │ presumably because energy from sidelobes bounces off the many scatterers in the rough │ │ surface of the cinder blocks. If the Ping))) unit is placed in a small box, the unit │ │ can be mounted against the wall without trouble. Chris' installation appears to be │ │ optimal: [URL]http://forums.parallax.com/forums/default.aspx?f=21&m=176721[/URL] │ │ •A note on temperature compensation...a temperature variation of 0 deg F to 100 deg F will │ │ change the resultant distance measurement by √(560/460) or ~10%...not a big deal in most │ │ applications, but perhaps worth considering for those cases where a considerable range │ │ of ambient temperature is expected. │ │ │ │ See end of file for terms of use. │ └────────────────────────────────────────────────────────────────────────────────────────────┘ SCHEMATIC ─────────────────────────────── 2X: ┌───────────────────┐ │┌───┐ ┌───┐│ ││ ‣ │ PING))) │ ‣ ││ │└───┘ └───┘│ │ GND +5V SIG │ └─────┬───┬───┬─────┘ │ │  1K  └┘ └ to Prop ─────────────────────────────── }} CON _clkmode = xtal1 + pll16x ' System clock → 80 MHz _xinfreq = 5_000_000 'hardware constants pingA = 9 'pin-- ping))) A pingB = 8 'pin-- ping))) B 'software constants updaterate = 8 'range update rate when active (measurement cycles per second) ~15 max 'machine states #0, a, b VAR OBJ debug: "SerialMirror" 'Same as fullDuplexSerial, but can also call from subroutines ping: "dualPing" 'Updated ping object (dual channel fire & forget) PUB Init waitcnt(clkfreq * 5 + cnt) 'Start FullDuplexSerial Debug.start(31, 30, 0, 57600) Debug.Str(String("MSG,Initializing...",13)) 'Note: debug formatting is set up for use with plx-daq ping.calibrate(68) 'calibrate ping for ambient temperature=68 F main Pub Main| mark, distA, distB mark := cnt 'process initialization time dira[1] :=1 repeat ping.selectAB(a) 'Select channel A distA := ping.ReadPingIn 'read Ping))) channel A ' distA := ping.ReadPingTenths ping.fireping(pingA) 'restart measurement cycle on channel A ping.selectAB(b) 'Select channel B distB := ping.ReadPingIn 'read Ping))) channel B ' distB := ping.ReadPingTenths ping.fireping(pingB) 'restart measurement cycle on channel B 'Now have two new measurement values and have restarted the Ping))) measurement cycle... 'Cog is free to do other things while the next measurement cycle is runnning... distA := kalman1c(distA,0) 'Mild filtering to supress msmnt jitter distB := kalman1c(distB,b) 'Mild filtering to supress msmnt jitter Debug.Str(String("DATA, TIME, TIMER, ")) Debug.Str(String(" distA, ")) 'kick out measurement data for display Debug.Dec(distA) Debug.Str(String(" distB, ")) Debug.dec(distB) Debug.Str(String(13)) mark += clkfreq/updaterate waitcnt(mark) 'wait for next measurement frame [COLOR=#FF0000]Pub ReadPing| mark, distA, distB dira[7]:=1 'LED on pin 1 repeat if distB => 90 outa[7] :=0 if distB < 90 outa[7] :=1 mark += clkfreq/updaterate waitcnt(mark) [/COLOR] pri kalman1c(x_meas,AorB):x_ret ''Simple 1-D kalman filter for scalar random constant with simplified covariance model. ''Uses a constant covariance (and therefore hard-coded kalman gain). Simplifies/speeds ''up calculations. User must manually select gain, where gain is given by: ''gain = const / k_scale (high gainbelieve msmnts) ''Max filter update rate ~9000 samples/sec for 1 cog @ clkfreq=80 'Note: as implemented here, this is actually 2 filters, one for channel A and one for B 'Can easily delete the AorB functionality if only a single channel is desired x_prev[AorB] := x_cur[AorB] x_cur[AorB] := (x_prev[AorB] * k_scale + (k * (x_meas - x_prev[AorB]))) / k_scale ' Debug.Str(String(" x_meas, ")) ' Debug.dec(x_meas) ' Debug.Str(String(" x_prev, ")) ' Debug.Dec(x_prev[AorB]) ' Debug.Str(String(" x_cur, ")) ' Debug.dec(x_cur[AorB]) return x_cur[AorB] dat '-----------[ Predefined variables and constants ]----------------------------- k_scale long 65_536 '2^16 (scaling varible on K, needed because K is of order 1) k long 32_768 'Kalman filter gain, in this case 32_768 / 65_536 = 0.5 x_prev long 0,0 'Kalman filter estimate of x at previous timestep x_cur long 0,0 'Kalman filter estimate of x at current timestep DAT {{ ┌─────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├─────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and │ │associated documentation files (the "Software"), to deal in the Software without restriction, │ │including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense,│ │and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so,│ │subject to the following conditions: │ │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial │ │portions of the Software. │ │ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT│ │LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. │ │IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER │ │LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION│ │WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └─────────────────────────────────────────────────────────────────────────────────────────────────────┘ }}
You also have a local "ReadPing" method that you are not calling from anywhere. So your tests against 90 are never happening.
