New Cog Spin Issue?
Hello All,
I am having a problem, that I cannot find the answer to, and would love it if someone could help. The issue is that as you can see in my code. I initialize the direction of a pin in my main procedure(running in cog 0), then at a later point in time, I initialize my motor controller object, which then sets the pin to high. What I have noticed is that this code does not work unless I define the direction of the pin somewhere in the code running on the new cog before setting it high. Is this a property I am not aware of with the propeller, or a bug in my code? By the way, the only functionality I am asking about is the led on pin 16 not lighting up when the MC object starts. I have verified it gets a cog successfully by the way(cog 2) Note that if I simply add DIRA[16]~~ before the OUTA[16]~~ in the RunMotors procedure it works, but I already set it to output in the Main Object, so I am wondering why that is not working. Thanks!!
Main Object:
Name: Trevor Handermann
Abstract: Robot Main Control Class
CON
'Clocking settings
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PINS
'LCD PINS
LCD_CLK = 0
LCD_MOSI = 1
LCD_DC = 2
LCD_CS = 3
LCD_RST = 4
LCD_BL = 5
'MOTOR CONTROLLER PINS
LEFT_ENCODER = 6
RIGHT_ENCODER = 7
LEFT_MOTOR_PWM = 8
LEFT_MOTOR_DIR = 9
RIGHT_MOTOR_PWM = 10
RIGHT_MOTOR_DIR = 11
'Sensor Pins
IR_REMOTE = 12
'Standard Output Pins
STATUS_LED = 16
VAR
byte key
OBJ
LCD : "GraphLCDTextOnly"
Utilities : "Utilities"
IR : "IR"
num : "Simple_Numbers"
MC : "R5MotorController"
PUB Main
Begin the robot program
InitRobot
'Main Control Loop
repeat
'Get IR Key
key := IR.GetKey
if key <> 32
LCD.PrintString(num.dec(key))
LCD.PrintString(string(" "))
case key
2:
'Move Straight Forward
MC.SetMotors(1,1,80,80)
5:
'Stop Motors
MC.SetMotors(1,1,0,0)
4:
'Rotate Left
MC.SetMotors(0,1,50,50)
6:
'Rotate Right
MC.SetMotors(1,0,50,50)
8:
'Move Staight Backward
MC.SetMotors(0,0,80,80)
IR.ClearKey
Utilities.DelayMS(30) 'Delay to avoid constant processing during button pressing
else
next
repeat
Utilities.DelayS(5)
PUB InitRobot | tmp
Perform startup proceedures
'Set Pin Dirs
DIRA[STATUS_LED]~~
'Start the lcd
LCD.Init(LCD_CLK, LCD_MOSI, LCD_DC, LCD_CS, LCD_RST, LCD_BL)
'Start IR in new cog
IR.StartIRMonitor(IR_REMOTE)
'Start Motor Controller
tmp := MC.Init(LEFT_ENCODER, RIGHT_ENCODER, LEFT_MOTOR_PWM, LEFT_MOTOR_DIR, RIGHT_MOTOR_PWM, RIGHT_MOTOR_DIR)
DAT
MC Object:
Abstract: Dagu Rover 5 Motor Controller Class
CON
'Clocking settings
PWM_BASE_TIME = 100 'Time in microseconds that the PWM Keeps the motor on for each percent
VAR
long tstack[256]
byte leftenc, rightenc, leftpwm, leftdir, rightpwm, rightdir
byte lpwmpercent
byte rpwmpercent
byte cldir, crdir
byte cog
byte cogon
OBJ
PUB Init(leftencoder, rightencoder, leftmotorpwm, leftmotordir, rightmotorpwm, rightmotordir)
'Setup pins
leftenc := leftencoder
rightenc := rightencoder
leftpwm := leftmotorpwm
leftdir := leftmotordir
rightdir := rightmotordir
rightpwm := rightmotorpwm
'Set Pin Dirs
DIRA[leftenc]~
DIRA[rightenc]~
DIRA[leftpwm]~~
DIRA[rightpwm]~~
DIRA[leftdir]~~
DIRA[rightdir]~~
'Start motors at off, and forward
crdir := 1
cldir := 1
SetMotors(1, 1, 0, 0)
cog := cognew(RunMotors, @tstack) 'Init cog
return cog
PUB SetMotors(lftdir, rhtdir, lftpwmper, rhtpwmper) | rpwm, lpwm
lpwmpercent := lftpwmper
rpwmpercent := rhtpwmper
rpwm := 0
lpwm := 0
'Protect gears by disallowing immediate motor redirection
if cldir <> lftdir or crdir <> rhtdir
'If motor moving
if lpwmpercent > 0 or rpwmpercent > 0
'Stop Motors
rpwm := rpwmpercent
rpwmpercent := 0
lpwm := lpwmpercent
lpwmpercent := 0
'If either motor is changing direction, then wait for motors to stop, then set directions
if rpwm <> 0
Utilities.DelayMS(400)
OUTA[leftdir] := !lftdir 'Set dirs to inverse becuase motor control is hooked up reverse
OUTA[rightdir] := !rhtdir
cldir := lftdir
crdir := rhtdir
'Set new pwm's
lpwmpercent := lpwm
rpwmpercent := rpwm
rpwm := 0
PUB Stop
'Turn off cog
if cogon~
CogStop(cog)
PUB RunMotors
####Here is the issue, this does not light the led on pin 16#########
OUTA[16]~~
DIRA[leftpwm]~~
DIRA[rightpwm]~~
repeat
'Send pwm to motors
'LEFT MOTOR
if lpwmpercent <> 0 and lpwmpercent < 100
OUTA[leftpwm]~~ 'Turn on
Utilities.DelayUS(PWM_BASE_TIME*lpwmpercent) 'Keep on for multiple of percentage
OUTA[leftpwm]~ 'Turn off
Utilities.DelayUS(PWM_BASE_TIME*(100-lpwmpercent)) 'Keep off for multiple of 100-percentage
elseif lpwmpercent == 100
OUTA[leftpwm]~~ 'Full power!
elseif lpwmpercent == 0
OUTA[leftpwm]~ 'Motor Off
'RIGHT MOTOR
if rpwmpercent <> 0 and rpwmpercent < 100
OUTA[rightpwm]~~ 'Turn on
Utilities.DelayUS(PWM_BASE_TIME*rpwmpercent) 'Keep on for multiple of percentage
OUTA[rightpwm]~ 'Turn off
Utilities.DelayUS(PWM_BASE_TIME*(100-rpwmpercent)) 'Keep off for multiple of 100-percentage
elseif rpwmpercent == 100
OUTA[rightpwm]~~ 'Full power!
elseif rpwmpercent == 0
OUTA[rightpwm]~ 'Motor Off
DAT
Main Object:
CON
'Clocking settings
PINS
'LCD PINS
LCD_CLK = 0
LCD_MOSI = 1
LCD_DC = 2
LCD_CS = 3
LCD_RST = 4
LCD_BL = 5
LEFT_ENCODER = 6
RIGHT_ENCODER = 7
LEFT_MOTOR_PWM = 8
LEFT_MOTOR_DIR = 9
'Sensor Pins
IR_REMOTE = 12
STATUS_LED = 16
VAR
byte key
OBJ
IR : "IR"
PUB Main
InitRobot
'Main Control Loop
repeat
'Get IR Key
key := IR.GetKey
if key <> 32
case key
2:
5:
'Stop Motors
4:
'Rotate Left
6:
'Rotate Right
8:
IR.ClearKey
else
next
repeat
Utilities.DelayS(5)
PUB InitRobot | tmp
'Set Pin Dirs
DIRA[STATUS_LED]~~
'Start the lcd
DAT
MC Object:
CON
'Clocking settings
VAR
long tstack[256]
byte lpwmpercent
byte rpwmpercent
byte cldir, crdir
byte cog
byte cogon
OBJ
'Setup pins
'Set Pin Dirs
DIRA[leftenc]~
DIRA[rightenc]~
DIRA[leftpwm]~~
DIRA[rightpwm]~~
DIRA[leftdir]~~
DIRA[rightdir]~~
crdir := 1
cldir := 1
return cog
rpwm := 0
lpwm := 0
'If motor moving
'Stop Motors
rpwm := rpwmpercent
rpwmpercent := 0
lpwm := lpwmpercent
lpwmpercent := 0
if rpwm <> 0
cldir := lftdir
crdir := rhtdir
'Set new pwm's
lpwmpercent := lpwm
rpwmpercent := rpwm
rpwm := 0
PUB Stop
'Turn off cog
if cogon~
CogStop(cog)
PUB RunMotors
OUTA[16]~~
DIRA[leftpwm]~~
DIRA[rightpwm]~~
repeat
'Send pwm to motors
'LEFT MOTOR
'RIGHT MOTOR
DAT
Each cog has it's own OUTA and DIRA registers.
A COG cannot drive an output unless it's own DIRA is set to output.
Do look at the Propeller IO architecture diagrams in the Propeller manual that make all this clear if you understand some logic operations (AND, OR, XOR...)
If you don't understand those come back and ask.
Welcome to the forum and happy Propelling !
