Help with XB and the FullDuplexSerial4 object — Parallax Forums
SteveWoodroughSteveWoodrough Posts: 190
edited 2013-11-16 16:26 in Propeller 1
I’m experimenting with my XB modules and have come across an inconsistency that has me puzzled.
If I use the DIO and FDS4 objects through a wired port the method SimpleDecimalReceiveFDS4_PST below works just fine even with multiple digit entries.
If, however, I try and take the same approach with the XB using SimpleDecimalReceiveFDS4_XB the program “hangs” waiting for the first entry?
Any ideas?
Thank You,
Steve
CON
_clkmode        = xtal1 + pll16x
'_clkfreq        = 80_000_000
_xinfreq        = 5_000_000
  PST = 0                       ' Port for Communication to PST
'  LCD = 1                       ' Port for Communication to LCD Tx only
  GPSPort = 2                   ' Port for Communication to GPS Rx only
  XB1    =   3                   ' Port for Xbee1
  XB2   = 0
  PST_BAUD = 9_600            ' PST baud rates, debug to terminal
  LCD_BAUD = 19_200             ' LCD baud rate
  GPS_BAUD = 9_600              ' GPS baud rate
  XB1_BAUD = 9_600               ' XB Baud Rate
  XB2_BAUD = 9_600               ' XB Baud Rate
'  BT_BAUD =  115_200            ' BT baud rate
'Pin Assignements:
'   BTTx    =  0                  'Tx Pin for Blue Tooth Module run in View Port
'   BTRx    =  1                  'Rx Pin for Blue Tooth Module run in View Port
   XB1Tx    = 0                   'XB DOut
   XB1Rx    = 1                   'XB DIN Pin
   XB2Tx    = 6                   'XB DOut
   XB2Rx    = 7                   'XB DIN Pin
   ServoPinX = 4
   ServoPinY = 2
   LCD_TXPIN = 4                 ' LCD Tx pin
   LCD_RXPIN = -1                ' LCD Rx pin THERE IS NONE
   GPS_TXPIN = 14                ' GPS Tx
   GPS_RXPIN = 15                ' GPS Rx pin
   PST_TXPIN = 30                 ' PST Tx Pin
   PST_RXPIN = 31                 ' PST Rx Pin
   CR = 13
VAR
   Long X, Y, Z
   word Stack[50]
OBJ
servo:           "servo32v7"
FDS4:             "FullDuplexSerial4port"
dio :            "dataIO4port"
FDS:            "FullDuplexSerialPlus"
XB:             "XBee_Object"
Pub Initialization            |index
 servo.start                                            'Start Servo Object
 Start_Uarts                                            'Starts FDS4port Object in its own cog.
 pause(1000)
Pub  SimpleDecimalReceiveFDS4_XB | Value
   Pause (3000)
  FDS4.str(XB1,string("Awaiting Data..."))                    'Notify base
  FDS4.tx(XB1,CR)
  Repeat
    FDS4.str(XB1,string(13,"Enter First Value: "))                             '
    Value:=dio.DecIn(XB1)                                       'Wait for and accept decimal value
    FDS4.str(XB1,string(13,"Value entered: "))
    Dio.dec(XB1,Value)
    FDS4.str(XB1,string(13,"Enter Second Value: "))
    Value:= Value + dio.DecIn(XB1)
    FDS4.str(XB1,string(13,"Total Entered: "))
    dio.dec(XB1,Value)
    FDS4.tx(XB1,CR)                                                 'Send CR to Base
Pub  SimpleDecimalReceiveFDS4_PST | Value
  Pause (3000)
  FDS4.str(pst,string("Awaiting Data..."))                    'Notify base
  FDS4.tx(pst,CR)
  Repeat
    FDS4.str(pst,string(13,"Enter First Value: "))
    Value:=dio.DecIn(PST)                                       'Wait for and accept decimal value
    FDS4.str(pst,string(13,"Value entered: "))
    Dio.dec(pst,Value)
    FDS4.str(pst,string(13,"Enter Second Value: "))
    Value:=Value + dio.DecIn(PST)                                       'Wait for and accept decimal value
    FDS4.str(pst,string(13,"Total Entered: "))
    Dio.dec(pst,Value)
    FDS4.tx(PST,CR)                                                 'Send CR to Base
PUB start_uarts
'' port 0-3 port index of which serial port
'' rx/tx/cts/rtspin pin number                          #PINNOTUSED = -1  if not used
'' prop debug port rx on p31, tx on p30
'' cts is prop input associated with tx output flow control
'' rts is prop output associated with rx input flow control
'' rtsthreshold - buffer threshold before rts is used   #DEFAULTTHRSHOLD = 0 means use default=buffer 3/4 full
''                                                      note rtsthreshold has no effect unless RTS pin is enabled
'' mode bit 0 = invert rx                               #INVERTRX  bit mask
'' mode bit 1 = invert tx                               #INVERTTX  bit mask
'' mode bit 2 = open-drain/source tx                    #OCTX   bit mask
'' mode bit 3 = ignore tx echo on rx                    #NOECHO   bit mask
'' mode bit 4 = invert cts                              #INVERTCTS   bit mask
'' mode bit 5 = invert rts                              #INVERTRTS   bit mask
'' baudrate                                             desired baud rate, e.g. 9600
  fds4.init                        ' sets up and clears the buffers and pointers, returns a pointer to the internal fds4 data structure
                                  ' always call init before adding or starting ports.
'****IMPORTANT NOTE:  TURN OFF PST PORT IF YOU PLAN TO USE VIEW PORT.****
  fds4.AddPort(XB1,XB1Tx,XB1Rx,-1,-1,0,0,XB1_BAUD)
  fds4.AddPort(XB2,XB2Tx,XB2Rx,-1,-1,0,0,XB2_BAUD)
  fds4.AddPort(PST, PST_RXPIN, PST_TXPIN,-1,-1,0,0,PST_BAUD) ' debug to the terminal screen, without flow control, normal non-inverted mode
'  fds4.AddPort(LCD, LCD_RxPIN, LCD_TXPIN,-1,-1,0,0,LCD_BAUD) ' Sends data to LCD screen
'  fds4.AddPort(GPSPort, GPS_RxPIN, GPS_TXPIN,-1,-1,0,0,GPS_BAUD) ' Receive data from GPS
' port 1, 2, 3 are not used.   The order that you define ports does not matter.  You don't have to do anything to set up unused ports
  fds4.Start
  pause(1000)   ' delay to get going before sending or receiving any data
PUB PAUSE(Duration) | cntS                              'Liberated from BSLite
   cntS:=cnt
   repeat ||Duration
    waitcnt(cntS+=clkfreq/1000)
    edited 2013-11-13 23:18
    5thDimension found a bug in the object, dataIO4port. I think it might cause the issue you are having.
    Look within the method "StrInMax". If it says uarts.rx(0), BUG alert!, change it to uarts.rx(port) as highlighted.
    [SIZE=1][COLOR=#020FC0][FONT=courier new]PUB StrInMax(port, stringptr, maxcount) | char, ticks
    {{from PST, modified Receive a string of characters (either carriage return terminated or maxcount in length) and stores it (zero terminated)starting at stringptr.  Waits until either full string received or maxcount characters received.}}
       maxcount <#= MAXSTR_LENGTH
      repeat maxcount
        if (byte[stringptr++] := [B]uarts.rx([/B][/FONT][B][FONT=courier new]port[/FONT][/B][FONT=courier new][B])[/B]) == NL
                        quit
          [/FONT][/COLOR][/SIZE][SIZE=1][COLOR=#020FC0][FONT=courier new]byte[stringptr+(byte[stringptr-1] == NL)]~ [/FONT][/COLOR][/SIZE]
  • SteveWoodroughSteveWoodrough Posts: 190
    THANK YOU!! That fixed it.
    Regards
    Steve
