BLDC 3-phase power board.
I'm building a BLDC drive and am using up some Harris G32N60E2 IGBTs. The modern version has been taken over by Intersil. I know I need a resistor between the gate drive and the gate pin on the IGBT. I read through the spec sheet for this part but didn't spot the guidance on a value for this resistor. Also I know I need a diodes between the collectors and the emitters. The IGBTs can carry a nominal 30 amps and I doubt I'll drive a PWM signal much above 8,000 hz. The diode must be able to survive the transient surges when the gate goes from conduction to non-conducting. Where could I find some design guidance on these two parts? The DC bus for this board won't exceed 400 volts and the steady-state current per phase won't exceed 5 amps. This is a hall effect sensored design utilizing a drum drive motor from a Samsung washing machine. It is an 18 slot motor.
of the driver chip to set the gate current. With paralleled devices there are differential oscillation
modes that are damped by gate resistors, so they are needed then. Well that's with MOSFETs,
IGBTs may be less sensitive to such things as the gate and channel are more isolated from the drain.
That said a gate resistor can be used to limit the slew rate - though this will increase losses it will
tame the higher frequencies of EMI output from the bridge. A resistor can also be part of the protection
circuitry - add a zener or TVS across gate/emitter and the resistor will limit the current to the
zener (remember significant emitter bounce can happen, adding to Vge).
For the diode fast recovery is important, and if you use synchronous rectification then it only
carries pulses of 30A so the pulse rating is appropriate. Otherwise you'll have to go for continuous
rating.
Things get hairier the higher the voltage (IGBTs are more robust than MOSFETs though) so taking
a lot of care to consider failure modes and adding protection circuitry is, I understand it, important.
I've built H-bridges running upto 38V with MOSFETs myself, I would strongly recommend an iterative
process, increasing the voltage and current a step at a time and testing each time looking for problems,
once things go wrong at these power levels the result is silicon vapour.... I'd either wear eye-protection
or have the devices behind a screen, they can and do explode under fault conditions.
The weak points are gate-emitter voltage limits, with these devices its +/-20V, yet the recommended
gate drive is 15V, so -5V of emitter bounce could kill the devices. Low inductance on the emitter
path is vital and 4-wire connection (separate gate/emitter twisted pair feed to the driver with emitter
leads commoned as close as possible the device?)
Other weak point is the raw power from the supply and its decoupling should shoot-through occur -
this is what vaporizes devices, here you have 400V and 30A, thats 12kW (the power of a small car
engine!). Choose drivers with built in shoot-through protection and generous or adjustavble dead-time,
be prepared to tune deadtime (you need more for higher currents as they take longer to switch off).
Good luck there!
on the same 1/2 bridge (while another 1/2 bridge switches high to low) - this is then exactly like a standard H-bridge.
