LiFePO4 batteries — Parallax Forums
LiFePO4 batteries
prof_brainoprof_braino Posts: 4,313
edited 2013-11-10 10:12 in General Discussion
I just discovered LiFePO4 batteries.
http://en.wikipedia.org/wiki/Lithium_iron_phosphate_battery
These have a lesser energy density, but are supposed to be more forgiving for over under charging, and can last longer than NiMH or other lithium battery types.
I checked a rechargeable battery pack from 2007, and to my surprise, it still works just fine. Compare this to all my Dell and HP laptop battery packs which have all died after 2 1/2 years whether I abuse them or not.
Anybody else use these? Insights?
    edited 2013-11-09 10:20
    I have a Palm Zire72 that is roughly 10 years old and still charges fine on the original battery pack. ... It could be LiFePO4.
    All sorts of claims that they are environmentally superior as the form of Lithium they use is found in a natural mineral state. But if they do burst and flame up at all, fluoride gases from the internal insulation seem a bit nasty to me.
    Overall, they are generally considered the best choice going forward into the future for a lithium cell chemistry.
    Meanwhile, we are having more electric car fires due to battery packs being ruptured by hitting objects on the roadway.
    Chinese vendors often confuse LiFePO4 and LiPO (which is Lithium Polymer technology), so you really have to be careful when shopping. I thought the two were the same for quite awhile, and they just may be in some cases... but not always... and I am beginning to believe they never are.
    You might buy an electric bicycle that touts LiFePO4 and get LiPO instead.
    edited 2013-11-09 10:43
    The user of 18650 or `14505 cells has to take responsibility to turn off the cell at 3.0 volts or the first use may just be the last. I built a nice little robot with two 18650 cells and let a kid play with it. He didn't turn it off, so the brand new cells were shot when it was handed back to me for recharge.
    edited 2013-11-09 10:52
    Interesting point in posts 14 & 15: The Dreamliner batteries were spec'd 8 years ago, before the LiFePO batteries were available. So they very easily passed all the safety checks -known-at-the-time-. Apparently it would have been nobody's job to go back and check, if that work was done by temporary contractors instead of full time employees. Makes more sense now.
  • Mark_TMark_T Posts: 1,981
    edited 2013-11-09 16:31
    LiFePO4 cells are 3.2V, not 3.7V as with most Li cells, so they are great for powering 3.3V logic devices directly!
    The max voltage is 3.6 or so, which most 3.3V chips handle. One LiFePO4 cell can replace 2 alkaline rather well
    too, 4 in series make a good 12V supply...
    Generally I favour them.
  • ErlendErlend Posts: 612
    edited 2013-11-10 01:00
    There is an ever-expanding jungle of Li-Ion chemistries, all with different pro's and con's. Here's one overview, but don't get too exited about the facts, there are also a whole range of priorities and choices to be made when deciding on the mechanical/chemical construction of the batteries - these all affect the price/performance/characteristics result. Basically, there is no answer to "which battery is best", but instead you have a number of trade-offs to make. The best way may be to go for a reputable make, e.g. Panasonic, and trust they have made good trade-off decisions.
    Erlend
    edited 2013-11-10 01:38
    While the LiFePO4 is indeed a 3.2volt chemistry that seems to have great functional appeal for use with 3.3volt logic, but be careful...the logic should be able to tolerate much higher voltages.. say 5.0v.
    Why so? Look at the actual high voltage limit of charging the LiFePO4. 3.2volt represents the bulk of the power delivery, but if the device is being charged while in operation it is going to get 3.6 volts, and maybe a bit higher.
    Since most chips limit over-voltage tolerance to about 10% and 110% of 3.3 volt ooperation 3.52 volts, there is a potential for problems.
    Regarding Boeing and the Dreamliner's choice of Lithium chemistry...
    It is all rather mysterious as to why Li Cobalt was selectied. Since the end of WWII, Japan and Germany have been paricipants in the Trilateral Commision that decides substantial issues of technology transfer between the USA, Germany, and Japan... behind closed doors. It may also negotiate why Japan buyings so much US debt in the form of bonds, and a lot of other issues that the public isn't aware of.
    Boeing seems to have not backed off of the Li Cobalt cells, just reconfigured safety features. The actual available total energy may have favored Li Cobalt.
    The ever-expanding chemistry alternatives for Lithium still struggle with two core issues.
    A. Lithium metal burns at low temperatures and in air if given a chance.
    B. Batteries are being constructed from foils and coatings that are progressively thinner... physically easier to harm.
    I strongly suspect that Lithium cells and maybe all newer battery cells are much safer and simpler in single cell applications. Two cells in series requires more management. And when 3 or more cells are put into a series configuration, control of charging, discharging, damage, and thermal runaway are still nasty.
  • pmrobertpmrobert Posts: 677
    edited 2013-11-10 06:11
    Yes, when they're good they're very good but when they're bad they're a big problem. Some of the motorcycle lithium battery mfgrs include the balancing circuitry and logic in the battery as they are also quite fragile and you're always one overcharge or full discharge from either fire or a permanently damaged battery that is $2-300 to replace. That said, I use them in the bikes as the weight savings is huge and I keep them on a proper trickle charger when not being ridden anyway.
    edited 2013-11-10 06:16
    A year or so back I did a lot of research into the active and passive balancing during charging and discharge of Lithium cells.
    It seems that the more you try to do, the more power you waste in the process, the more time you add to the recharge cycle, and that the results are often worse than minimal management.
    edited 2013-11-10 07:02
    Individual chips vary but a lot of 3.3V chips quite often have a 3.0V to 3.6V range, or 2.7V to 3.6V.
    3.3 x 1.1 = 3.63V, not 3.52V. Abs max are usually higher still.
    edited 2013-11-10 09:42
    Mark_T wrote: »
    Okay.. my math was off. But some leeway in the the top end of charging these does exist... a charger may go to 3.7 volts instead of 3.6. The cell would then deliver 3.7 volts for awhile.
    It is just important to be aware that the operating range is from about 3.0 to 3.6 or 3.7 and to make sure your project can adapt to the full range.
