Gas sensor help
I was looking into gas sensors. http://www.parallax.com/catalog/sensors/gas and i see that there is a gas sensor board for the gas sensors. Is the board used to make it so that the outputs are digital? Because the gas sensors alone are analog? Also from the data sheet it shows that there are 4 pins on the board. One for ground,Power, ALR, HSW. The data sheet says input for detecting the alarm signal (ALR) and the other an output for controlling the internal heater (HSW). I am kinda confused on ALR and HSW. ALR is the alarm that triggers that something is wrong? HSW is the output to the microcontroller to tell you something is wrong? Also can you tell me what HSW mean. I tried to google ALR and HSW but i still don't get it.
Thanks for your time.
