Best lead free solder (wire)?
Bill Henning
I've been doing a bit of soldering on a lead free prototyping board... and it is painful with my 40W temperature controlled iron and the leaded solder I normally use.
It takes 3x as long before the solder will adhere to the holes! It simply refuses to adhere to the Pb-free surface until it is REALLY heated.
Does anyone know of a faster way? Or should I invest in a 100W soldering iron? (mostly joking)
Also some good flux may help.
http://www.hakko.com/english/products/hakko_fx888d.html
Peter
I've tried both a Weller and a soldering station similar to your hakko - same issue soldering to lead free pcb. I'll try some flux.
Andrew:
The cheap PCB's use an "unknown" pb-free process. I have zero problem melting my leaded solder, on my on tinned or gold flash pcb's its extremely easy to solder. The prototype board is not old, nor oxidized, just some no-name brand/process (it was small, and a shape I needed, so I tried it... time to make some of my own small proto pcb)
Franklin:
I have no problem soldering to non-lead free pcb's, or gold flashed lead free pcb. Too bad, I was hoping for a lead-free magic bullet
ALL:
On "good" pcb's I heat the pad for <2sec and make a nearly perfect solder joint immediately on applying solder - no beading, no problems adhering
On these "funny" pcb's I have to head the pad for >8sec to get a not so good looking joint. If I apply the solder before heating the pad for at least 8 sec, the solder just beads and does not adhere to the pads.
Both "good" and "funny" soldered with same irons, and same solder (with flux core)
Funny pcb's: new, small, unknown lead-free process
Thanks guys!
Wifey is picking up three more different types of solder for me during her lunch, and a 60W soldering iron. I'll be picking up some flux as well (if I can't find my stash of flux for smt).
Hopefully I will solve this issue.
If the flux etc won't help, maybe I'll call in a favor and have the metal analyzed at a lab.
I did a number of experiments, and it seems I can solder to these lead free boards reasonably well at 400'C or higher (using my Gordak 952 rework station).
I'll try it tonight with an inexpensive 60W iron.
For what its worth, I've had zero problems soldering nice gold flash lead free boards with the 40W Weller. Had to bring out the big guns for this PCB.
if so, a LiGhT rub with a FiNe scotchbrite will buff them enough to break through the surface oxides.
I've used abrasive cleanser as well, but the PTH's must be flushed extremely well or you will make
more problems for yourself.
rinse,rinse,rinse and repeat.
dry thoroughly and (vacuum) bag them if you must wait to use the stock.
I suspect that most of the boards shipped from China are deficient in rinsing after processing.
Who knows what demons are left under the solder masking on cheap boards.
Stick to Pb 60/40 and call them 'Hi-Rel' boards for lab work, you will have less problems especially in reflow work.
jr
