Propeller Backpack Video Problem
I have a small surplus of these small TFT displays. I can drive the display with the composite video output from a DVD player with no problem. I can drive a TV monitor with the backpack with no problem as well. However, if I try to drive the display with the backpack, it cooks the composite video input of the display and its no longer usable. The first one I thought was a fluke. The second one though I confirmed worked perfectly before hooking it up to the backpack, now it just gives a white screen.
So, as far as power and ground go, the display takes 8 volts. The ground shares the same ground as the composite video shield wire. The backpack is on that same ground as well, but is powered from a separate 5 volt regulator.Does anybody know of a way to prevent this damage from happening? I feel like I need to isolate the grounds from each other, but cannot figure out how. Maybe im totally off base....
Sonny
Sonny
The backpack expects the displays it drives to have a 75-ohm input impedance. Check to make sure the resistance across the display's input leads is 75 ohms. If it's not, add a 75-ohm resistor across the Backpack's video output. This will limit the output voltage to 1V P-P from 2V P-P. Still, though, it would be highly unusual for a 2V signal to destoy a video input, since all non-loaded video sources output the same 2V P-P signal.
You could also have a common-mode voltage difference between your two grounds. Disconnect the Backpack from the monitor, and connect the grounds together through a 100K resistor and measure the voltage across it. It should be zero.
Also, I did check the datasheet for the display and it lists the Vp-p to be 1 volt typical and 2 volts max.
I did also verify that the two grounds going in to the display are connected together by a fairly wide trace on the board.
Sonny
