Which microcontroller to usean — Parallax Forums
edited 2013-11-06 15:14 in General Discussion
Hello,
I am looking to develop a prototype for a project that I've been working on and I'm looking for advice on which microcontroller to use. I need a microcontroller that will fulfill my requirements but am not looking to spend a lot of money on features/abilities that I don't need. My only real requirements are to record and log data from a couple of different sensors and then display this data on a screen of some type. I would also like the microcontroller to be able to communicate with the sensors wirelessly (the sensors being powered separately and located within inches of the microcontroller. The other, most important, aspect is that it needs to be fairly small. I was also wondering if I decided to get a development board to run my tests and do my programming first and then complete the actual prototype on a small mountable microcontroller would there be any issues due to differences between the two? Any thoughts or advice would be helpful.
    edited 2013-11-05 12:48
    Propeller, AVR, NXP, Cirrus, Freescale, ARM chips. These all come in small packages and have development boards. Some of your requirements depend on things other than the micro though so you will need to research that.
  • jmgjmg Posts: 15,199
    edited 2013-11-05 13:15
    How much data ?
    ...and then display this data on a screen of some type.
    ?? a screen of some type is extremely vague. Graphics or Numeric ? What format display, size of digits, update rate ... ?
    wirelessly ? - as in Infrared, Zigbee, WiFi, Bluetooth ?
    fairly small also needs numbers ?
    A display + batteries is likely to dictate the size.
    There are a number of starter boards that include simple displays, (STm, Freescale,TI ?) but the wireless-included is less common on smaller uC boards.
    edited 2013-11-05 13:25
    towne107@canton.edu,
    You have told us everything but you have told us nothing.
    Good. What sensors? How fast would you like to do this?
    I would also like the micro-controller to be able to communicate with the sensors wirelessly (the sensors being powered separately and located within inches of the micro-controller.
    OK. But now we have a different problem. Not how to interface to the sensors but how to interface to the wireless communication devices.
    By the way, if the sensors are only "inches away" why do you want to make things a hundred times more expensive and complicated using wireless rather than a direct wired connection?
    Yes, but if you put all that wireless communication in between it will be big.
    Now, how about you tell us what you really want to measure with those sensors? And how fast? Then we can think about a good solution.
    edited 2013-11-05 18:49
    I think you might like the propeller for a couple reasons:
    It supports video built in and you can use s twenty dollar car backup camera monitor from eBay or any NTSC, pal,vga display out of the box.
    Several boards have xbee header and an sd card slot built in.
    You can program in C/C++/spin/forth. There are more objects in spin, but the c system is really easy to get going.
    There are cheap small versions of boards where you can still do sd data logging because there is a spot for sd card.
    The SS card object and video is very common on propeller.
    Any micro can do a lot of what you want, these are reasons I recommend the propeller.
    edited 2013-11-06 11:30
    Wireless communications with sensors is going to significantly increase your costs.
    And each end of the wireless is going to require a microcontroller. Sensors don't magically communicate with wireless.
    If you want to save money, RS-422/485 serial wire can go to 1000 meters easily on two wires.
    The Propeller can use a Micro SDcard to record data, so you have gigabytes of space if you require such.
    The Propeller can support a keyboard and VGA color monitor with ASCII display (no Chinese yet).
    You could make the Propeller your base station and have your wired sensors connect to small limited purpose microcontrollers that are connected to one sensor each over an RS-422.
    In other words, if money is really an issue, using different micro-controllers for different purposes may save you more than using one micro-controller for everything. But you would have to learn how to use different programing tools for each.
    Of course, if you use Propeller chips for everything, you will get excellent support from this forum... better that most of what is out there.
    edited 2013-11-06 11:41
    Would the size of a fingertip be the size you're looking for?
    The RFDuino may be what you want...
    http://www.kickstarter.com/projects/1608192864/rfduino-iphone-bluetooth-40-arduino-compatible-boa
    They're still shipping to backers, though, and haven't yet started taking normal orders.
    edited 2013-11-06 11:49
    FWIW, what won me over to the Propeller was my very first project with it. Primarily, I needed precise IO timing (fraction of a microsecond accuracy, fraction of a microsecond latency) to run a bunch of power equipment, but I also needed some sort of user interface.
    The ability to download a piece of canned software and immediately have a VGA display, PS/2 kbd interface, and even a mouse interface, was mind-blowing. It was mind-blowing that it would do all those things, but it was even more amazing that it would do all those things without compromising in the slightest the precise timing of the primary function.
  • Mark_TMark_T Posts: 1,981
    Well XBees do support analog sensors automatically don't they?
    But my main point is that almost any wireless solution is cheaper than a 1000m of weatherproof UTP cable, 1000m
    range isn't a selling point for RS485, its the reliability and bandwidth that would sell it to me.
