TB6560 request for feedback
I've seen posts on several forums stating that the TB6560 is prone to blowing-up. I recall seeing this in relation to multiple axis CNC drivers. And many stating that's impossible to do a single power supply design that will not violate the recommended start-up procedure (see page 28 in http://www.toshiba-components.com/docs/linear/TB6560AHQ_en_datasheet.pdf)
For reference see:
However, did someone have any trouble with these cheap boards ??
The reason I ask is that these boards have correctly tied the RESET and ENABLE pins of the TB6560 to a RC network (R between +5V and the pins and C between pins and Gnd) that will hold low both pins until C charges from the stabilized +5V regulator. This IMHO will keep the TB6560 in a high Z state until both voltages (motor and logic) stabilize. This, I guess, should prevent simultaneous drivings on the high and low sides of the outputs.
Any experience/coments on these?
Alex
For reference see:
Alex
http://www.piclist.org/techref/io/stepper/THB6064/index.htm
Rick
EDIT: The 6064 does seem to have better protection. You can see the same power-up procedure as the TB6560 stated in page 35 of the datasheet for TB6064AH (http://www.piclist.org/images/massmind/THB6064AH_ENG.pdf) but it also says the IC will not break even if the sequence is not followed.
Also the reason I ask about TB6560 board is that I already have many for a small CNC project and was wondering is there is any difference in reliability between these single axis drivers and the multiple axis boards.
Alex
