OpenSpin build on Raspberry Pi Errors - BOOM! — Parallax Forums
mindrobotsmindrobots Posts: 6,506
edited 2013-11-19 10:43 in Propeller 1
I'm building OpenSpin on my Raspberry Pi.
I'm on the latest Raspian (9-25-2013) and I grabbed the latest OpenSpin (r53)
After unzipping it into a directory, I do a 'make clean' and then 'make all'
This is my build output:
pi@tornado ~/src/openspin-source-r53 $ make all
make -C PropellerCompiler all
make[1]: Entering directory `/home/pi/src/openspin-source-r53/PropellerCompiler'
g++ -DGCC -Wall -g -static -o BlockNestStackRoutines.o -c BlockNestStackRoutines.cpp
g++ -DGCC -Wall -g -static -o CompileDatBlocks.o -c CompileDatBlocks.cpp
g++ -DGCC -Wall -g -static -o CompileExpression.o -c CompileExpression.cpp
g++ -DGCC -Wall -g -static -o CompileInstruction.o -c CompileInstruction.cpp
g++ -DGCC -Wall -g -static -o CompileUtilities.o -c CompileUtilities.cpp
g++ -DGCC -Wall -g -static -o DistillObjects.o -c DistillObjects.cpp
g++ -DGCC -Wall -g -static -o Elementizer.o -c Elementizer.cpp
g++ -DGCC -Wall -g -static -o ErrorStrings.o -c ErrorStrings.cpp
g++ -DGCC -Wall -g -static -o ExpressionResolver.o -c ExpressionResolver.cpp
g++ -DGCC -Wall -g -static -o InstructionBlockCompiler.o -c InstructionBlockCompiler.cpp
g++ -DGCC -Wall -g -static -o StringConstantRoutines.o -c StringConstantRoutines.cpp
g++ -DGCC -Wall -g -static -o SymbolEngine.o -c SymbolEngine.cpp
g++ -DGCC -Wall -g -static -o Utilities.o -c Utilities.cpp
g++ -DGCC -Wall -g -static -o PropellerCompiler.o -c PropellerCompiler.cpp
ar rs libopenspin.a BlockNestStackRoutines.o CompileDatBlocks.o CompileExpression.o CompileInstruction.o CompileUtilities.o DistillObjects.o Elementizer.o ErrorStrings.o ExpressionResolver.o InstructionBlockCompiler.o StringConstantRoutines.o SymbolEngine.o Utilities.o PropellerCompiler.o
ar: creating libopenspin.a
make[1]: Leaving directory `/home/pi/src/openspin-source-r53/PropellerCompiler'
g++ -o openspin -DGCC -Wall -g -static SpinSource/openspin.cpp SpinSource/flexbuf.c SpinSource/preprocess.c PropellerCompiler/libopenspin.a
SpinSource/openspin.cpp:76:26: error: ‘PATH_MAX’ was not declared in this scope
SpinSource/openspin.cpp:79:38: error: ‘PATH_MAX’ was not declared in this scope
SpinSource/openspin.cpp: In function ‘const char* MakePath(PathEntry*, const char*)’:
SpinSource/openspin.cpp:83:13: error: ‘lastfullpath’ was not declared in this scope
SpinSource/openspin.cpp: In function ‘FILE* OpenFileInPath(const char*, const char*)’:
SpinSource/openspin.cpp:142:28: error: ‘lastfullpath’ was not declared in this scope
SpinSource/openspin.cpp:149:12: error: ‘filesAccessed’ was not declared in this scope
SpinSource/openspin.cpp:149:47: error: ‘lastfullpath’ was not declared in this scope
SpinSource/openspin.cpp: In function ‘int main(int, char**)’:
SpinSource/openspin.cpp:507:28: error: ‘filesAccessed’ was not declared in this scope
SpinSource/openspin.cpp:516:17: error: ‘filesAccessed’ was not declared in this scope
SpinSource/openspin.cpp:85:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [all] Error 1
About 1/2 way through it starts complaining about things.
Is there anything special I need to do for building on a Linux environment?
Any help would be appreciated.
Thanks!
  • jazzedjazzed Posts: 11,803
    edited 2013-11-04 13:18
    You're out of date :)
    $ svn update
    sh-3.1$ svn update
    At revision 57.
    svn checkout http://open-source-spin-compiler.googlecode.com/svn/ open-source-spin-compiler-read-only
    edited 2013-11-04 13:32
    HEY! Oh, my code.
    Interesting, I'll grab the new one later tonight. Wonder where I picked the old one up? (Totally rhetorical on that one.)
    Thanks, Steve!
    edited 2013-11-04 13:41
    mindrobots wrote: »
    But, but, but, but ... oh snap! :)
    edited 2013-11-06 16:31
    This thread probably solved Rick's issues, but may still have left other Raspberry Pi owners scratching their heads...
    Here's a step-by-step method of obtaining and compiling Open Spin on the Raspberry pi.
    wget -r http://open-source-spin-compiler.googlecode.com/svn/
    cd open-source-spin-compiler.googlecode.com
    cd svn
    make clean
    make all
    Finally, run the binary with the following...
    ./openspin
    Jeff
  • RaymanRayman Posts: 14,824
    edited 2013-11-06 16:47
    OpenSpin huh... Sounds nice. Where did this come from?
    edited 2013-11-06 17:15
    Jeff, one thread to solve my issues!?!?!? Wow, I've been years developing them!
    @Ray, Roy Eltham took Chip's spin compiler code and ported it to C++ a while back. It gets burried and then dug up every few months. It should be a sticky or better advertised somehow.
    edited 2013-11-06 19:25
    Oh, that's Roy's code. I knew about that, just forgot the name. Thanks.
    edited 2013-11-07 04:28
    So is openspin ready for public consumption? Can us regular folk use it without hurting ourselves?
  • RsadeikaRsadeika Posts: 3,837
    edited 2013-11-07 05:25
    I guess all you need now is something like a Geany IDE with the correct build instructions, and you are ready to go. I use Geany a lot, and it is a very capable IDE, the only thing that would be missing is the screen functionality of Propeller Tool, indentation control.
    Ray
    edited 2013-11-07 08:08
    Braino,
    ...is openspin ready for public consumption?
    I would say yes, give it a try. MInd you I would build it from the latest sources. I'm sure any bug reports would be welcome. There may be issues with code that is normally built with BST as I'm not sure all of the BST Spin extensions are in there yet.
    https://code.google.com/p/open-source-spin-compiler/source/checkout
    Ray,
    Don't let Jazzed hear you say that:)
    Why would you want Geany IDE when you can use Simple IDE?
    SimpleIDE does everything you need for Spin programming: editing, syntax highlighting, compiling, prop loading, terminal screen etc. Also works for C if you want.
    edited 2013-11-07 08:47
    My suggestion was strictly for POC working with openspin, as soon as they have 'sudo apt-get install simpleide', then there will be no need for Geany.
    Ray
    edited 2013-11-07 10:47
    We had an openspin mishap today during testing.
    In SimpleIDE, I loaded the Parallax Serial Terminal Demo.spin file, and set the project.
    Compiled and loaded the binary, but nothing happened on Propeller.
    The problem is a build issue which I've seen before with make.
    I recommend always doing make clean after svn update.
    Roy, considering how small openspin is, it would be good to add clean to the build steps in Makefile.
    I.E. change: "all: $(LIBNAME) Makefile" to "all: clean $(LIBNAME) Makefile"
    Heater. wrote: »
    LOL I recommended the Geany IDE for development long ago since it is so easy to configure.
  • RetrobitsRetrobits Posts: 46
    I was just trying to compile openspin on the RasPi today, and lo and behold, this thread.
    Now it's working like a charm.
    Thanks as always folks...
    - Earl
