Nwebie Propeller Quickstart question — Parallax Forums
jujugoboomjujugoboom Posts: 6
edited 2013-11-07 16:33 in Propeller 1
Hello,
I just bought my parallax propeller quickstart 40000 today from radioshack. Ive worked for a while with arduino and decided, why not try out the propeller. I downloaded the drivers and propeller tool and loaded up the touch example. I do not have any external peripherals right now so i just decided to mess around with using multiple cores and printing to the serial terminal. I used this code
CON
  _CLKMODE = XTAL1 + PLL16X
  _CLKFREQ = 80_000_000
OBJ
  Buttons          : "Touch Buttons"
  PST              : "Parallax Serial Terminal"
PUB Main
  cognew(Touch(_CLKFREQ/100), @stack[0])
PUB Touch
  dira[23..16]~~                                        ' Set the LEDs as outputs
  repeat
    outa[23..16] := Buttons.State
to try to get it to start in a new cog. It gives me the error stating that it expected a , at touch in the cognew command. I was also wondering which way is the best way to have it read which button i press and output it to pst? Such as "Button 0 Pressed","Button 1 Pressed" etc etc. Thanks for any help
Justin
    edited 2013-11-03 20:55
    jujugoboom wrote: »
    That's to be expected because the Touch method doesn't take any parameters. Either use cognew(Touch, @stack[0]) or change Touch to accept a parameter, e.g. PUB Touch(delay). You'll also have to define a stack array somewhere.
    edited 2013-11-03 21:55
    I tried to keep a list of QuickStart related links and demos in this thread.
    My QuickStart servo tester uses the buttons to set the servo parameters. I gave Joe some instructions on how to use the touchpads as selection buttons starting in post #15 of his QuickStart BOE-Bot thread.
    Post #3 of my index has links to various Propeller tutorials.
    You might have a hard time going back to the Arduino once you see how useful parallel processing can be on the Propeller.
  • jujugoboomjujugoboom Posts: 6
    edited 2013-11-04 17:45
    Duane Degn wrote: »
    Thats alot of great resources. Thanks. I am a slow learner though. When i run this code
    CON
    OBJ
    PUB Main
      cognew(touch(clkfreq/100), @stack)
    PUB touch(delay)
      repeat
        outa[23..16] := Buttons.State                       ' Light the LEDs when touching the corresponding buttons
    I get an error stating it was expecting a variable at
    @stack
    edited 2013-11-04 21:33
    jujugoboom wrote: »
    @stack
    Correct, all you have to do is define one so it can be used, e.g.
    VAR
      long  stack[32]
    It's advisable to start with a generously sized stack and adjust it later if necessary.
    edited 2013-11-06 14:55
    I'd try this out with the tutorials or examples in the help menu of the ide. Its hard to go back from parallel processing once you've started. Get an activity board next to try the cool stuff and have fun.
    edited 2013-11-06 19:38
    Alright so ive been doing some looking around and came up with this.
    CON
    VAR
      long stack[60]
    OBJ
      NUM              : "Numbers"
    PUB Main
      cognew(touch(clkfreq/100), @stack[0])
      cognew(terminal, @stack[30])
    PUB touch(delay)
      repeat
    PUB terminal
      PST.start(115200)
      repeat
        PST.clear
        PST.dec(Num.ToStr(Buttons.State, Num#DDEC)- 16)
        waitcnt(clkfreq / 10 + cnt)
    of course if you compile and run this you will see that it doesn't work, at all. I was able to get the buttons to work in a seprerate cog but then adding PST broke it. Any help would be appreciated.
    edited 2013-11-06 19:57
    I'm still staring at your code in the attempt to figure out what broke... Haven't spotted it yet, perhaps MikeG or someone will beat me to the punch...
    In the meantime, you may find the Programs on this link useful. IIRC, there is a game or two that used both the Serial Terminal and the Touchbuttons.
    Jeff
    edited 2013-11-06 20:08
    jujugoboom wrote: »
    ... of course if you compile and run this you will see that it doesn't work, at all. I was able to get the buttons to work in a seprerate cog but then adding PST broke it. Any help would be appreciated.
    The Touch Buttons objects I know of need to be started (e.g. Buttons.Start(rate)). I can't find this call in your example. Also, depending on how the State method is written the terminal cog and the display cog may get into each others way.
    Also, what's the idea behind PST.dec(Num.ToStr(Buttons.State, Num#DDEC)- 16)?
  • dgatelydgately Posts: 1,633
    edited 2013-11-06 22:55
    jujugoboom wrote: »
    CON
    VAR
      long stack[60]
    OBJ
      NUM              : "Numbers"
    PUB Main
      repeat                                         ' <==  need this repeat to keep the HUB running
    PUB touch(delay)
      Buttons.start(delay)                        ' <== need to start the Buttons object
      dira[23..16]~~
      repeat
    PUB terminal
      PST.start(115200)
      repeat
        PST.clear
        PST.bin(Buttons.State,8)             ' <== use "bin" as it will show a binary representation of the button state (8 bits worth!)
        waitcnt(clkfreq / 100 + cnt)           ' <== need to give a little time for PST to keep up with this tight loop!
    There are still issues with how quickly the two loops run. The display of the button states to PST flicker and the LEDs of non-pressed buttons light unless your touch is very light.
    dgately
    edited 2013-11-07 07:22
    dgately wrote: »
    CON
    VAR
      long stack[60]
    OBJ
      NUM              : "Numbers"
    PUB Main
    PUB touch(delay)
      dira[23..16]~~
      repeat
    PUB terminal
      PST.start(115200)
      repeat
        PST.clear
    dgately
    I dont have my propeller with me right now but this looks like it should work. Are you saying that it just needs some delays because i can easily add that in. So all i needed to do was start buttons? Thanks
    edited 2013-11-07 07:39
    jujugoboom wrote: »
    And you were using the Numbers object incorrectly. PST has some built in methods for dealing with numbers so you don't need the "Numbers" object at all.
    I think you'd get a better looking display if you didn't clear the screen with each loop but instead use the PST Position method to print the same line over the same location. I think the clear screen command will make the screen flicker a bit.
    edited 2013-11-07 09:30
    Duane Degn wrote: »
    Yes, I was quickly trying to solve his issue and wasn't really thinking about why the flicker. Always best to just update by setting the X,Y position of the cursor, especially when the output is a known number of characters.
    Thanks Duane! As usual, great advice from a sage Propeller dude :thumb:
    dgately
    edited 2013-11-07 16:17
    dgately wrote: »
    dgately
    And, sorry to ask so many questions, without putting in into the code, how would you propose doing that? Thanks
    edited 2013-11-07 16:25
    jujugoboom wrote: »
    You can check-out all of Parallax Serial Terminal's functions/methods in its .spin file... But, here's an example...
    I dont remember of the .Position method is ZERO-based or not, so try one of these in place of 'PST.clear':
        PST.Position(0, 0)
    OR
        PST.Position(1,1)
    dgately
    dgately wrote: »
        PST.Position(0, 0)
    OR
        PST.Position(1,1)
    dgately
    Yes using
    PST.Position(0,0)
    is the proper one to use
