I am working on a tap tempo device that I want to have multiple midi outs. I could send duplicate signals on different pins, but I'd rather daisy chain them. Does anyone see any problems with the attached schematic? I don't know know enough about hardware to tell myself.
Thanks!
I would recommend using 1 buffer per port. This is possibly overkill but will keep you in MIDI spec.
+1. The chip may not be able to drive 2 ports properly.
*open collector output
*IOH 250uA
*IOL 40mA
I'd go with a buffer per port as it would provide better isolation between ports should something go goofy.
