' ========================================================================= ' ' File....... 24LC08.BS2 ' Purpose.... 24LC08 demo with a BS2/BS2e/BS2sx ' Author..... Jon Williams, Parallax ' E-mail..... jwilliams@parallax.com ' Started.... ' Updated.... 10 SEP 2004 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[ Program Description ]--------------------------------------------- ' -----[ Revision History ]------------------------------------------------ ' -----[ I/O Definitions ]------------------------------------------------- SDA PIN 0 ' I2C serial data line SCL PIN 1 ' I2C serial clock line ' -----[ Constants ]------------------------------------------------------- Ack CON 0 ' acknowledge bit Nak CON 1 ' no ack bit EE24LC08 CON %1010 << 4 ' -----[ Variables ]------------------------------------------------------- slvAddr VAR Byte ' I2C slave address devNum VAR Nib ' device number (0 - 7) addrLen VAR Nib ' bytes in word addr (0 - 2) wrdAddr VAR Word ' word address i2cData VAR Byte ' data to/from device i2cWork VAR Byte ' work byte for TX routine i2cAck VAR Bit ' Ack bit from device test VAR Nib outVal VAR Byte inVal VAR Byte fails VAR Word ' -----[ EEPROM Data ]----------------------------------------------------- ' -----[ Initialization ]-------------------------------------------------- Check_Module: #IF ($STAMP >= BS2P) #THEN #ERROR "Use I2COUT and I2CIN!" #ENDIF Setup: addrLen = 1 ' one word address byte DEBUG CLS DEBUG "24LC08 Demo ", CR, "---------------", CR, "Address... ", CR, "Output.... ", CR, "Input..... ", CR, "Status.... ", CR, "Errors.... " ' -----[ Program Code ]---------------------------------------------------- Main: fails = 0 FOR wrdAddr = 0 TO 1023 ' test all locations slvAddr = EE24LC08 | (wrdAddr.BYTE1 << 1) ' set block bits DEBUG CRSRXY, 11, 2, DEC4 wrdAddr FOR test = 0 TO 3 ' use four patterns LOOKUP test, [$FF, $AA, $55, $00], outVal DEBUG CRSRXY, 11, 3, IHEX2 outVal i2cData = outVal GOSUB Write_Byte PAUSE 10 GOSUB Read_Byte inVal = i2cData DEBUG CRSRXY, 11, 4, IHEX2 inVal, CRSRXY, 11, 5 IF (inVal = outVal) THEN DEBUG "Pass " ELSE fails = fails + 1 DEBUG "Fail ", CRSRXY, 11, 6, DEC fails EXIT ' terminate location ENDIF PAUSE 10 NEXT NEXT IF (fails = 0) THEN DEBUG CRSRXY, 11, 6, "None. All locations test good." ENDIF END ' -----[ Subroutines ]----------------------------------------------------- ' =====[ High Level I2C Subroutines]======================================= ' Random location write ' -- pass device slave address in "slvAddr" ' -- pass bytes in word address (0, 1 or 2) in "addrLen" ' -- word address to write passed in "wrdAddr" ' -- data byte to be written is passed in "i2cData" Write_Byte: GOSUB I2C_Start ' send Start i2cWork = slvAddr & %11111110 ' send slave ID (write) GOSUB I2C_TX_Byte IF (i2cAck = Nak) THEN Write_Byte ' wait until not busy IF (addrLen > 0) THEN IF (addrLen = 2) THEN i2cWork = wrdAddr.BYTE1 ' send word address (1) GOSUB I2C_TX_Byte ENDIF i2cWork = wrdAddr.BYTE0 ' send word address (0) GOSUB I2C_TX_Byte ENDIF i2cWork = i2cData ' send data GOSUB I2C_TX_Byte GOSUB I2C_Stop RETURN ' Random location read ' -- pass device slave address in "slvAddr" ' -- pass bytes in word address (0, 1 or 2) in "addrLen" ' -- word address to write passed in "wrdAddr" ' -- data byte read is returned in "i2cData" Read_Byte: GOSUB I2C_Start ' send Start IF (addrLen > 0) THEN i2cWork = slvAddr & %11111110 ' send slave ID (write) GOSUB I2C_TX_Byte IF (i2cAck = Nak) THEN Read_Byte ' wait until not busy IF (addrLen = 2) THEN i2cWork = wrdAddr.BYTE1 ' send word address (1) GOSUB I2C_TX_Byte ENDIF i2cWork = wrdAddr.BYTE0 ' send word address (0) GOSUB I2C_TX_Byte GOSUB I2C_Start ENDIF i2cWork = slvAddr | %00000001 ' send slave ID (read) GOSUB I2C_TX_Byte GOSUB I2C_RX_Byte_Nak GOSUB I2C_Stop i2cData = i2cWork RETURN ' -----[ Low Level I2C Subroutines ]--------------------------------------- ' *** Start Sequence *** I2C_Start: ' I2C start bit sequence INPUT SDA INPUT SCL LOW SDA Clock_Hold: DO : LOOP UNTIL (SCL = 1) ' wait for clock release RETURN ' *** Transmit Byte *** I2C_TX_Byte: SHIFTOUT SDA, SCL, MSBFIRST, [i2cWork\8] ' send byte to device SHIFTIN SDA, SCL, MSBPRE, [i2cAck\1] ' get acknowledge bit RETURN ' *** Receive Byte *** I2C_RX_Byte_Nak: i2cAck = Nak ' no Ack = high GOTO I2C_RX I2C_RX_Byte: i2cAck = Ack ' Ack = low I2C_RX: SHIFTIN SDA, SCL, MSBPRE, [i2cWork\8] ' get byte from device SHIFTOUT SDA, SCL, LSBFIRST, [i2cAck\1] ' send ack or nak RETURN ' *** Stop Sequence *** I2C_Stop: ' I2C stop bit sequence LOW SDA INPUT SCL INPUT SDA RETURN
Assuming that your EEPROM is I2C, then yes.... What is the part number of the EEPROM?
This link may be helpful:
http://forums.parallax.com/showthread.php/82908-I2C-On-A-BASIC-Stamp
Thank you for your help
' ========================================================================= ' ' File....... 24LC08.BS2 ' Purpose.... 24LC08 demo with a BS2/BS2e/BS2sx ' Author..... Jon Williams, Parallax ' E-mail..... jwilliams@parallax.com ' Started.... ' Updated.... 10 SEP 2004 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[ Program Description ]--------------------------------------------- ' -----[ Revision History ]------------------------------------------------ ' -----[ I/O Definitions ]------------------------------------------------- SDA PIN 0 ' I2C serial data line SCL PIN 1 ' I2C serial clock line ' -----[ Constants ]------------------------------------------------------- Ack CON 0 ' acknowledge bit Nak CON 1 ' no ack bit EE24LC08 CON %1010 << 4 ' -----[ Variables ]------------------------------------------------------- slvAddr VAR Byte ' I2C slave address devNum VAR Nib ' device number (0 - 7) addrLen VAR Nib ' bytes in word addr (0 - 2) wrdAddr VAR Word ' word address i2cData VAR Byte ' data to/from device i2cWork VAR Byte ' work byte for TX routine i2cAck VAR Bit ' Ack bit from device test VAR Nib outVal VAR Byte inVal VAR Byte fails VAR Word ' -----[ EEPROM Data ]----------------------------------------------------- ' -----[ Initialization ]-------------------------------------------------- Check_Module: #IF ($STAMP >= BS2P) #THEN #ERROR "Use I2COUT and I2CIN!" #ENDIF Setup: addrLen = 1 ' one word address byte DEBUG CLS DEBUG "24LC08 Demo ", CR, "---------------", CR, "Address... ", CR, "Output.... ", CR, "Input..... ", CR, "Status.... ", CR, "Errors.... " ' -----[ Program Code ]---------------------------------------------------- Main: fails = 0 FOR wrdAddr = 0 TO 1023 ' test all locations slvAddr = EE24LC08 | (wrdAddr.BYTE1 << 1) ' set block bits DEBUG CRSRXY, 11, 2, DEC4 wrdAddr FOR test = 0 TO 3 ' use four patterns LOOKUP test, [$FF, $AA, $55, $00], outVal DEBUG CRSRXY, 11, 3, IHEX2 outVal i2cData = outVal GOSUB Write_Byte PAUSE 10 GOSUB Read_Byte inVal = i2cData DEBUG CRSRXY, 11, 4, IHEX2 inVal, CRSRXY, 11, 5 IF (inVal = outVal) THEN DEBUG "Pass " ELSE fails = fails + 1 DEBUG "Fail ", CRSRXY, 11, 6, DEC fails EXIT ' terminate location ENDIF PAUSE 10 NEXT NEXT IF (fails = 0) THEN DEBUG CRSRXY, 11, 6, "None. All locations test good." ENDIF END ' -----[ Subroutines ]----------------------------------------------------- ' =====[ High Level I2C Subroutines]======================================= ' Random location write ' -- pass device slave address in "slvAddr" ' -- pass bytes in word address (0, 1 or 2) in "addrLen" ' -- word address to write passed in "wrdAddr" ' -- data byte to be written is passed in "i2cData" Write_Byte: GOSUB I2C_Start ' send Start i2cWork = slvAddr & %11111110 ' send slave ID (write) GOSUB I2C_TX_Byte IF (i2cAck = Nak) THEN Write_Byte ' wait until not busy IF (addrLen > 0) THEN IF (addrLen = 2) THEN i2cWork = wrdAddr.BYTE1 ' send word address (1) GOSUB I2C_TX_Byte ENDIF i2cWork = wrdAddr.BYTE0 ' send word address (0) GOSUB I2C_TX_Byte ENDIF i2cWork = i2cData ' send data GOSUB I2C_TX_Byte GOSUB I2C_Stop RETURN ' Random location read ' -- pass device slave address in "slvAddr" ' -- pass bytes in word address (0, 1 or 2) in "addrLen" ' -- word address to write passed in "wrdAddr" ' -- data byte read is returned in "i2cData" Read_Byte: GOSUB I2C_Start ' send Start IF (addrLen > 0) THEN i2cWork = slvAddr & %11111110 ' send slave ID (write) GOSUB I2C_TX_Byte IF (i2cAck = Nak) THEN Read_Byte ' wait until not busy IF (addrLen = 2) THEN i2cWork = wrdAddr.BYTE1 ' send word address (1) GOSUB I2C_TX_Byte ENDIF i2cWork = wrdAddr.BYTE0 ' send word address (0) GOSUB I2C_TX_Byte GOSUB I2C_Start ENDIF i2cWork = slvAddr | %00000001 ' send slave ID (read) GOSUB I2C_TX_Byte GOSUB I2C_RX_Byte_Nak GOSUB I2C_Stop i2cData = i2cWork RETURN ' -----[ Low Level I2C Subroutines ]--------------------------------------- ' *** Start Sequence *** I2C_Start: ' I2C start bit sequence INPUT SDA INPUT SCL LOW SDA Clock_Hold: DO : LOOP UNTIL (SCL = 1) ' wait for clock release RETURN ' *** Transmit Byte *** I2C_TX_Byte: SHIFTOUT SDA, SCL, MSBFIRST, [i2cWork\8] ' send byte to device SHIFTIN SDA, SCL, MSBPRE, [i2cAck\1] ' get acknowledge bit RETURN ' *** Receive Byte *** I2C_RX_Byte_Nak: i2cAck = Nak ' no Ack = high GOTO I2C_RX I2C_RX_Byte: i2cAck = Ack ' Ack = low I2C_RX: SHIFTIN SDA, SCL, MSBPRE, [i2cWork\8] ' get byte from device SHIFTOUT SDA, SCL, LSBFIRST, [i2cAck\1] ' send ack or nak RETURN ' *** Stop Sequence *** I2C_Stop: ' I2C stop bit sequence LOW SDA INPUT SCL INPUT SDA RETURNCheck out this link : (you will want to look for nv115 within the download)
http://www.parallax.com/downloads/nuts-and-volts-basic-stamps-volume-5
