USB driver issues
Hi. I have a Boe-bot with the Board of Education installed on it. I also have a laptop that is running Xubuntu 13.10 on it.The editor works fine, but when I try to run a program, the editor replies "No usable serial ports found." I also tried installing the USB drivers via Wine, but that still has not solved the problem. Are there any existing driver installer files for Linux, or will I have to use someone else's computer?
It could be your Wine installation, or something else in the chain of items required to reach the serial port.
Can you see a USB serial port that is active in your /dev directory.? It should be something like ttyUSB0. If you have an cative ttyUSB0 in /dev, the driver is working fine. You can unplug your USB device and the ttyUSB0 will disappear. When you plug it in again, it will reappear.
Personally, I don't use Wine as early on it was infamous for not properly supporting serial ports just for this purpose. It is supposed to be fixed, so you may require a newer version of it.
by-id contains a file named usb-FTDI_FT232R_USB_UART_A70056bo-if00-port0. I tried clicking on both of them, but it brought me to the menu to select which program to open them. Should I just use the drivers link that NWCCTV suggested?
