Good place to buy 22 different colored / striped 50 to 100 ft lengths of 18 AWG wire?
As the titles says, I need to purchase 22 different color combinations of wire, but I can't afford 500ft reels right now. I am hoping to locate at least 20 difference colors, but 22 would be best. Any suggestions?
I often buy a hunk of such cable locally to provide me a yard or so of diverse color selections. I then strip off the outer covering and use the individual wires on projects as required. Much better than buying 100 feet of 25 colors and nevery using most of the stuff.
And do they really need to be 22 colours?
Best I can find is 10 colours:
http://www.ebay.com/itm/Stranded-Equipment-Wire-18AWG-20AWG-22AWG-24AWG-26AWG-28AWG-Cable-Cord-Hook-up-/221290053954?pt=UK_BOI_Electrical_Components_Supplies_ET&var=&hash=item3385ea4142#ht_9251wt_852
(There are some selling 11 colours, too, but I couldn't find any selling 18 awg)
If all you are seeking is different colors/striped, then perhaps an automotive wiring harness might be a source. If 50 feet is an actual requirement, then perhaps an airplane salvage yard may have what you need.
Bruce
If they are for sensors do you really need 18ga.?
Also I assume this is for an automotive enviroment, do you need gas and oil proof insulation?
C.W.
Jameco has 25 conductor cables, not twisted pair in lesser lengths (like 25 feet and 100 feet), but 24awg.
http://www.jameco.com/1/1/1904-sc25-25vp-cable-shielded-25-conductor-gray-24awg-25-feet.html
http://www.jameco.com/1/1/2437-sc25-100vp-cable-shielded-25-conductor-gray-24awg-100-feet.html
