NOECHO problem with fullduplexserial4port v1.01 — Parallax Forums
dbpagedbpage Posts: 217
edited 2013-11-23 19:05 in Propeller 1
I am converting multiple fullduplexserial drivers running in 4 cogs to fullduplexserial4port v1.01 (obex.parallax.com/object/248) running in 1 cog. Two channels require Tx/Rx to be on the same one pin to communicate with a Parallax Serial Controller (PSC) and a Digital Output Controller (DC or DC16), both running 2400 baud. I currently communicate with each using FullDuplexSerial_rr004 (obex.parallax.com/object/249) configured as shown below, and there are no Tx issues. With fullduplexserial4port, Tx is unreliable. I have isolated this issue to NOECHO. The behavior is identical on all 4 ports (0 to 3).
With fullduplexserial4port, if there is no cable or device connected to the output pin, Tx/Rx hangs on the Rx that follows Tx when NOECHO is set (see fullduplexserial4port code below). If there is a cable or device connected to the output pin, there is no issue. With NOECHO turned off, Rx receives all Tx characters reliably with or without a cable or device connected. There is no issue with fullduplexserial_rr004. This makes me think there is a timing issue in the fulduplexserial4port code somewhere. As you can see, the fullduplexserial and fullduplexserial4port Tx/Rx spin code are essentially identical, so, perhaps the problem is in PASM. Can you help me find the problem?
Original
OBJ
  psc       : "FullDuplexSerial_rr004"               ' Communicate with Parallax Servo Controllers
  DC16      : "FullDuplexSerial_rr004"               ' Communicate with Digital Output Controllers
CON
  PSCcom        = 15                            ' Pin to transmit to PSC Parallax servo controller
  PSCmode       = %1100                         ' PSC Communication Mode: open-drain/source tx/ignore tx echo on rx
  PSCbaud       = 2400                          ' PSC Baud Rate
  DCcom         = 14                            ' Pin to transmit to DC16 digital controller
  DCmode        = %1100                         ' Digital Controller Communication Mode: open-drain/source tx/ignore tx echo on rx
  DCbaud        = 2400                          ' Digital Controller Baud Rate
PUB i
  psc.start(PSCcom,PSCcom,PSCmode,PSCbaud)      ' Start psc communication service (rxpin,txpin,mode,baudrate)
  DC16.start(DCcom,DCcom,DCmode,DCbaud)            ' Start DC16 communication service (rxpin,txpin,mode,baudrate)
' Display PSC version number
  psc.str(string("!SCVER?",CR))                 ' Send version command to PSCs
' rx routine goes here
' Display DC16 version number
  repeat i from 0 to 6                          ' Send command to DC16
     DC16.tx(DC16text[N])
DAT
  DC16text byte "!DC16",3,"V",0,0
'Comment:
'mode bit 0 = invert rx
'mode bit 1 = invert tx
'mode bit 2 = open-drain/source tx
'mode bit 3 = ignore tx echo on rx
'mode bit 4 = invert cts
'mode bit 5 = invert rts
New:
CON
  PSCport       = 2                             ' PSC serial port number
  DCport        = 3                             ' Digital controller serial port number
OBJ
  ser       : "fullDuplexSerial4port"                     ' 4 channel serial communication
PUB i
  ser.AddPort(PSCport,PSCcom,PSCcom,-1,-1,0,PSCmode,PSCbaud)' Initialize PSC serial communication port
  ser.AddPort(DCport,DCcom,DCcom-1,-1,0,DCmode,DCbaud)' Initialize DC serial communication port
  ser.str(PSCport,string("!SCVER?",CR))         ' Send version command to PSCs
' Display DCversion number
FullDuplexSerial_rr004:
PUB rx : rxbyte
'' Receive byte (may wait for byte)
'' returns $00..$FF
  repeat while (rxbyte := rxcheck) < 0
PUB tx(txbyte)
'' Send byte (may wait for room in buffer)
  repeat until (tx_tail <> (tx_head + 1) & bufmsk)
  tx_buffer[tx_head] := txbyte
  tx_head := (tx_head + 1) & bufmsk
  if rxtx_mode & %1000
    rx
CON
  NOECHO                        = %001000
PUB rx(port) : rxbyte
'' returns $00..$FF
  repeat while (rxbyte := rxcheck(port)) < 0
PUB tx(port,txbyte)
  if port > 3
    abort
  repeat until (tx_tail[port] <> (tx_head[port] + 1) // txsize[port])
  byte[txbuff_ptr[port]+tx_head[port]] := txbyte
  tx_head[port] := (tx_head[port] + 1) // txsize[port]
  if rxtx_mode[port] & NOECHO
    rx(port)
  • Tracy AllenTracy Allen Posts: 6,664
    edited 2013-10-27 14:23
    I find that strange too. NoEcho is a spin-only implementation in both cases, simply reading and throwing away the character that follows each tx.
    One thing catches my attention, and thank you for the careful description. The fact that it happens only when the cable is detached might have something to do with the fact that the 4port code discards bytes that have a framing error, that is, those that lack a stop bit. The other program does not reject framing errors and can put out a stream of null bytes when the serial line stays in a BREAK state. A floating cable can be a great source of framing errors. That's just a thought. I haven't tracked through the code to follow how that could explain your observation. Why do you need for this to operate with the cable disconnected? If that is the case, it should have a pullup resistor (or pulldown if inverted) to hold the line in the Stop state so that it can't float.
  • dbpagedbpage Posts: 217
    edited 2013-10-27 18:39
    I tried a pull-up resistor, and the behavior is unchanged.
    When I turn NOECHO off, Tx no longer hangs and I get some garbage and then the echo. I am not so sure the problem is isolated to NOECHO, as I so confidently stated before. I pointed the object to the PSC terminal with NOECHO and OCTX, at 2400 and 9600 baud, with separate Tx and Rx pins, and there seems to be an issue receiving characters from the PSC.
    I'll have to look into this further to understand the issue. Something else might be going on; however, when I switch back to fullduplexserial_rr004, the behavior returns to normal.
    I'll look into it over the next few days. If you spot something, let me know.
  • Mike GMike G Posts: 2,702
    edited 2013-10-28 04:50
    Do you have a schematic?
    I use the attached when connecting a half-duplex device to a full-duplex port.
    744 x 356 - 44K
    edited 2013-10-28 08:03
    "When I turn NOECHO off, Tx no longer hangs and I get some garbage and then the echo."
    Hmmm. You have to wonder where the garbage is coming from. With the pullup resistor, the line should be quiet between the tx and the rx. Is it possible that there is electrical noise coming from the servos or valves? This is where an oscilloscope or Saleae can help, to visualize the signal. I can't think at the moment why 4port would react differently than 1port, though, unless it is issue issue of stop bits.
    (Love the fountain, by the way. I grew up in Battle Creek MI and my sister still lives in Montague, north of Benton Harbor.)
    edited 2013-10-29 20:24
    I performed the following experiments tonight.
    I fixed an unrelated problem and pointed fulldupexserial4port to the Parallax serial terminal with mode = 0, 9600 baud, separate Tx and Rx pins, and there seems to be *no* issue. Characters are transmitted and received properly.
    I pointed fullduplexserial4port to an empty pin with mode = $1100 (NOECHO & OCTX), 2400 baud, Tx/Rx on the same pin, and no pull-up resistor, no cable connected and it hangs on Rx after Tx.
    I added a pull-up resistor, and fullduplexserial4port does *not* hang. I connected the cable and the PSC, and fullduplexserial4port does *not* hang, but no characters are received.
    My connections, which have been successful with fulldupexserial_rr004, with NOECHO and OCTX, 9600 baud, Tx/Rx on pin, for many years with no issue, follows:
              3.3V            5V
               &#61463;              &#61463;
         &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9524;&#9472;&#9472;&#9472;&#9472;&#9488;15    &#9484;&#9472;&#9472;&#9524;&#9472;&#9472;&#9488;PWM &#9484;&#9472; Servo 0
         &#9474;P8X32A-Q44&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508; PSC &#9500;&#9472;&#9472;&#9472;&#9472;&#9532;&#9472; :
         &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9516;&#9472;&#9472;&#9472;&#9472;&#9496;      &#9492;&#9472;&#9472;&#9516;&#9472;&#9472;&#9496;    &#9492;&#9472; Servo 15
               &#61464;              &#61464;
    I run without a connection to continue development without a full compliment of peripherals.
    Your comments and suggestions will be appreciated. In the meantime, I will continue to look into this further to understand the issue. Something else might be going on, because when I switch back to fullduplexserial_rr004, same connections and settings, the behavior returns to normal.
    edited 2013-10-29 21:48
    Thanks for the careful experiments.
    issue #1:
    When you develop without a full complement of peripherals, can you leave a pullup resistor in place? Lacking the resistor, the tx byte you send pulls the line low and leaves it there. fds4port rejects framing errors, puts nothing in the rx buffer, and it hangs when it looks for the echo:
    [SIZE=1][FONT=courier new]  if rxtx_mode[port] & NOECHO
        rx(port)   ' discard the echoed character[/FONT][/SIZE]
    The fds-rr004 uart though will not lock, because it ignores the framing error, puts nulls (many of them) in the buffer, and thus, none the wiser, escapes from the trap. I feel that rejection of framing errors is important enough to keep. But I definitely don't like the potential lockup. I'm thinking I should change the rx(port) to rxTime(port, clkfreq*10 / baudrate), allowing it to stick there for just enough time for the tx pasm routine to send all the bits. That is tricky though, because the spin tx(port) routine does not have access to the baudrate parameter. I'll give it some thought but do let me know if you have suggestions about it. In the meantime, be sure to leave a pullup resistor in place for open baud modes.
    Issue #2:
    That I don't understand. I'm not familiar with how the PSC operates. What gets sent to the PSC, and what response are you expecting? It has a built-in pullup resistor for the shared rx/tx?
    As a related aside, I've used fds4port successfully for SDI12, which is a single wire common buss protocol, popular for environmental instrumentation.
    edited 2013-10-30 05:30
    There's no issue with leaving a pull-up resistor in the circuit. It's good practice with OCTX (open collector transmit). I'll do it.
    I considered modifying fullduplexserial4port with rxtime after tx, but I haven't thought through the issues with this. Right now I am more interested in knowing exactly why fullduplexserial4port behaves differently than fullduplexserial_rr004. You explained part of it with a change in the way the stop bit is handled. I wonder if the issue is in PASM or totally unrelated, such as another object stepping on a buffer or something.
    When the PSC receives the command "!SCVER?<cr>", it responds with the version number, such as, "1.2".
    The Rx routine goes like this:
    port := 2
    repeat M from 0 to 2
      Buff[M] := ser.rx(port)
    I'll experiment further and advise the results. Let me know if you think of something else for me to consider.
    edited 2013-10-30 09:25
    Is this the #28830 Propeller Serial Controller USB? I took a look at the documentation.
    When fds4port sends a position command such as
    "!SC", ch, ra, pw.LOWBYTE, pw.HIGHBYTE, CR
    Does the servo actually move to the new position? That is to inquire, is the issue only with receiving chars back from the PSC, or both with sending and receiving?
    edited 2013-10-30 19:19
    Yes, the PSC is #28830.
    That's the thing. It started before there. The start up sequence begins by sending a version command, receiving the version number, displaying the version number, then waits for a command from the host (Parallax Serial Terminal). fds4port hung, so we did not get to the point of sending a position command to the PSC.
    I began my troubleshooting at the version command, because Tx was hanging. I now know that Tx is working, and it was hanging on the Rx after Tx, so I focused on Rx. Once we got past that, I started getting garbage characters on Rx.
    I performed the following experiment tonight:
    CON
      HostPort = 0
      HostTx   = 30
      HostRx   = 31
      HostMode = 0
      HostBaud = 9600
    VAR
      byte Buff[6]
    OBJ
      ser : "dataIO4port"
    Pub Main
      ser.Init
      ser.AddPort(HostPort,HostRx,HostTx,-1,-1,0,HostMode,HostBaud)
      ser.Start
      ser.str(HostPort,string("Ready",13))
      repeat
        Buff[0] := ser.rx(HostPort)
        ser.tx(HostPort,Buff[0])
    PST displays "Ready" followed CR followed by a string of garbage characters. If I hit a key, PST displays the key, and continues to receive and display garbage characters. I expect fds4port to wait for a key to be hit, but it doesn't. Pins 30 and 31 are connected to the USB port, so there's no custom circuitry involved.
    edited 2013-10-30 20:13
    dbpage wrote: »
    The way it's shown you use RCFAST, NG. Once I replaced the serial object with FullDuplexSerial4port and added a crystal based clock setup this program works for me (@115200baud).
    edited 2013-10-31 16:42
    Oh, I see. The rx(port) object in dataIO4port points to rxcheck(port). I changed it to rx(port) and it works with PST fine. I will start working with fds4port directly until the problem is solved.
    Let's sum it up so far:
    - Use a pull-up resistor for when nothing is connected
    - Use rx, not rxcheck
    So, now back to the original problem. When I turn on NOECHO (%1000), fds4port does not transmit.
    I pointed fds4port to the USB port to see what happens on a Propeller Serial Terminal. It runs fine with PSCmode = 0, and hangs after displaying "R" with PSCmode = %1000. It hangs on the Rx after Tx.
    CON
      PSCcom        = 30                            ' Pin to communicate with PSC Parallax servo controller
      PSCmode       = %1000                         ' PSC communication mode (ignore tx echo on rx)
      PSCbaud       = 2400                          ' PSC baud rate
    VAR
      byte  Buff[6]                                 ' Serial input/output strings  ,PSCtext[8],DC16text[9]
    DAT
    ' PSC command string
      PSCtext  byte "!SCVER?",CR
    OBJ
      ser       : "fullduplexserial4port"                 ' 4 channel serial communication
    PUB Main  | I,J                                 '' Fountain Command Interpreter
      ser.Init                                      ' Initialize serial communication
      ser.AddPort(PSCport,PSCcom+1,PSCcom,-1,-1,0,PSCmode,PSCbaud) ' Initialize PSC serial communication port
      ser.Start                                     ' Start serial communication process
      waitcnt(clkfreq+cnt)
      ser.str(PSCport,string("Ready",CR))           ' Send welcome string
      repeat j from 0 to 7
        ser.tx(PSCport,PSCtext[j])                  ' Send command
      ser.str(PSCport,string("Version: "))
      repeat j from 0 to 2
        Buff[j] := ser.rx(PSCport)                  ' Get version number in "x.x" format
        ser.tx(PSCport,Buff[j])
      ser.str(PSCport,string(CR,"Done",CR))
    edited 2013-10-31 17:45
    dbpage wrote: »
    Yes, PST doesn't echo received characters back to the prop which means that your tx call blocks (in NOECHO mode) when there is no echo. If you type random characters in PST you will see your program progressing as each received character releases one rx block.
    edited 2013-10-31 18:03
    I'm puzzled, (as was Kuroneko) because the dataIO4port object does not have methods for rx(port) or rxCheck(port). DataIO4port is an add-on for fullDuplexSerial4port, and it is a compendium of methods for formatting output and input numerical and string data. The input methods do call uarts.rx(port) and uarts.rxCheck(port) as part of the blocking and non-blocking string input methods, but I don't see how that jives with your observation.
    The methods in dataIO4port were part of Tim Moore's original pcFullDuplexSerial4fc, plus methods that come from PST and other sources. I split it off from the core routines of fds4port. When both are used, they are declared as separate objects, or you can use different i/o methods, or you can merge dataIO4port back into fds4port. Is the latter what you have done, and called it "dataIO4port"? Can I surmise that in merger, somehow rx got pointed to rxCheck? A surmise.
    "I pointed fds4port to the USB port to see what happens on a Propeller Serial Terminal." I see you changed the pins over to 31 for rx and 30 for tx, and now you are attempting to send data to the computer. The prop transmits the "Ready" just fine when mode=0 but only the "R" when NOECHO is on. I am not sure that PST echos characters back to the prop. Well, I'm pretty sure it does not. I think if you press "R" on the PC keyboard, then the prop should move on to the "e", and so on. Your finger provides the echo. I know there is an "echo" check box on PST, but that turns on and off local echo of what you type at the PC, not echo of what the PC receives from outside. Some terminal programs do have remote echo as an option too. Or, you could make the Prop itself emulate a terminal with echo.
    I'll see if I can get ahold of a PSC so that I can follow along better.
    edited 2013-11-01 11:23
    I must have added rx(port) to dataIO4port myself. I removed dataIO4port yesterday (see the code in post #12 above). Since yesterday, all of my experiments act on fds4port directly.
    You're right. There is no echo to ignore when Tx and Rx are on different pins while using PST. Silly me. The object behaved as designed. I hope this embarrassing feeling dissipates quickly.
    I confirmed the following:
    - The PSC (aka PSCU) responds to commands typed into the PST when connected directly to the PC. The PST displays "1.4" after typing the command "!SCVER?<cr>"
    - fds4port properly receives echo characters when Tx and Rx are on the same pin and mode = 0
    - fds4port hangs when Tx and Rx are on the same pin and mode = %1000
    I know the echo characters are in the Rx buffer. I don't know why rx(port) is missing them in fds4port. I can read and display the echo characters with rx(port) in my object. It's a mystery why fds4port hangs at the identical rx(port) command (when the "if" statement is true):
      rx(port)
    Tonight I will add a little delay before the above "if" statement in fds4port to see if there is a timing issue.
    edited 2013-11-01 16:20
    A delay makes no difference.
    The PSC responds properly when directly connected to the PST. The PSC responds to commands issued by fds_rr004. The PSC does *not* respond to commands issued by fds4port.
    Next experiment: Take a look at the serial strings with an oscilloscope and compare fds_rr004 and fds4port outputs.
    edited 2013-11-01 18:08
    If you want to receive on a combined rx/tx pin shouldn't that at least involve the #OCTX bit, i.e. %1100?
    edited 2013-11-01 18:44
    The oscilloscope shows identical bit patterns, including the same number of stop bits, but there is a slight timing difference between fds_rr004 and fds4port outputs. I will explore that further tomorrow. Both are running at (yawn) 2400 baud and mode = 0.
    The objects look like this:
    OBJ
      ser1      : "fullduplexserial_rr004"
    <initialize stuff>
    PUB Main
      repeat
        ser.tx(PSCport,$55)
        ser1.tx($55)
        ser.tx(PSCport,$0)
        ser1.tx($0)
    edited 2013-11-01 18:51
    kuroneko,
    Yes. %1100 when Tx/Rx are on the same pin. %0 when Tx/Rx are on separate pins. I may have made a typo.
    edited 2013-11-02 16:17
    I changed to another Propeller board and fds4port works fine.
    Here's a summary of what I found communicating with PSC #28830 using either fds4port or fds_rr004:
    - Propeller Board of Education (#32900): NG
    - Propeller Activity Board #1 (#32910): NG
    - Propeller Activity Board #2 (#32910): NG
    - Board of Education (#28150) + Spin Stamp (#SS1-IC): No issues
    - Propeller Serial Controller USB + Parallax Serial Terminal (direct connection): No issues
    All boards are configured as follows:
    - I/O Pin #15
    - Mode %1100 (NOECHO + OCTX)
    - Baud 2400
    I will call this problem solved because it looks like my issue is not related to fds4port.
    Thank you so much for your help and support.
  • mr23mr23 Posts: 21
    edited 2013-11-02 20:38
    Have you been using BST or the Propeller Tool to compile ?
    edited 2013-11-02 22:42
    mr23 wrote: »
    I asked that because I found a difference in code operation between the two, on my prop code that accesses serial ports.
    I just found the source of my problem. I have been using BST for some time, but since starting to use it certain serial related code stopped working.
    Turns out it isn't a problem with the serial ports themselves, but the wrapper object I created that used the ObjectBoundHack as documented by jazzed in http://forums.parallax.com/showthread.php/120467-Procedure-variables-or-callbacks-in-spin?p=886310&viewfull=1#post886310. BST seems to be eliminating the fp1, fp2, fp3 object code as 'unused' since it isn't directly referenced. If I compile with Prop Tool, it works fine. If I turn off the "eliminate unused spin methods" compiler option in BST, then it partially works there.
    I'll post any followup on the referenced thread, since it isn't related to this thread. I ended up here because the symptoms were similar (serial output stalling, garbage output, etc, etc depending on combinations of things tried).
    edited 2013-11-04 10:01
    I have been using the Propeller Tool to compile.
    I will continue to experiment as I'm still seeing non-deterministic behavior.
    Thanks for your comments as I will use BST sometime in the future.
    edited 2013-11-04 17:39
    What am I doing wrong?
    I have been experimenting with demo2_FDS4port on my Propeller Activity Board #32910. The demo works as described at 57600 and 2400 baud. I am a bit curious about the Rx bits that are "discarded." I'd like to know where those "not strictly necessary" characters come from.
    Then, I changed the demo and circuit as follows, and it does not work:
      AB_BAUD = [B]2400[/B]
      fds.AddPort(A_PORT, -1, A_TXPIN, A_CTSPIN,-1, 0, [B]%1100[/B], abBaud)
    ' Schematic:
               3.3VDC
                &#61463;
      &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;10 &#61628; 1K
      &#9474;     &#9500;&#9472;&#9472;&#9472;&#9508;
      &#9474; PAB &#9474;8  &#9474;
      &#9474;     &#9500;&#9472;&#9472;&#9472;&#9496;
      &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    edited 2013-11-04 18:20
    dbpage wrote: »
    The NOECHO flag forces a call to rx. But as you don't have an rx pin specified (-1) this call can't possibly succeed.
    edited 2013-11-04 18:47
    That fixed it. Thanks
    edited 2013-11-17 10:52
    Just a now certainly off-topic follow-up... Although not certain, my issue was caused by BST eliminating code actually used (but via a hack, so I can't complain). Would be nice if there was a directive to force a .spin file to not be optimized... if anyone knows of one please share.
    mr23 wrote: »
    edited 2013-11-17 19:56
    @mr23, agreed, your question is far off topic, but I'll try a quick answer. On the bst/compiler preferences/optimizations, there is a check box for "Eliminate unused SPIN methods".
    edited 2013-11-18 21:06
    @dbpage, did you resolve the problem? I know you marked it "solved" but it seemed like the cause of the issue was still illusive.
    Not to leave it hanging. I made a little program to use fullDuplexSerial4port to set up two cogs to talk to one another over one wire, half duplex, using the open baudmode, OCTX+NOECHO. It launches one cog to emulate (weakly) the Parallax Servo Controller command set. So you can type in the command that gave trouble, "!SCVER?"<CR> and that will be transmitted out the master OCTX port to the slave and the slave will respond with "1.2". There are other commands too, fun with parsing.
    edited 2013-11-20 12:55
    Tracy Allen,
    I added a pull-up resistor and fds4port communicates fine with the PSC on all Propeller board versions over one wire with OCTX+NOECHO and 2400 open-mode baud. I conducted a number of experiments and although I did not determine the exact causes, I am no longer detecting non-deterministic behavior. I re-downloaded fds4port and dataIO4port and am using them as originally designed. I pushed rxtime out to 30ms as the USB PSC seems to respond differently than the serial PSCs. I am now confident that you and others identified the root causes of my various issues. Thank you.
    Is there a change I could make to so that fds4port will not hang with a framing error as described in your post #2? I would prefer that system always be responsive and not hang should there be a framing error.
    Dennis
    edited 2013-11-23 18:27
    That's great that the issue is mostly resolved. Chris from Parallax very kindly sent me a PSC/USB to try out, so please let me know if you run into any more mysterious problems with the serial interface using FDS4port. I'm having fun with the PSC myself. Most of my work has to do with boring measurements. Making things move is addictive!
    In my opinion, the occurrence of framing errors should be handled in the application Spin code. There are very few PSC commands that return feedback, anyway, the lack of return data can be handled with rxCheck or rxTime.
    If you really do want to remove the suppression of framing errors, you have to delete a line from the pasm code for each of the receive routines in fullDuplexSerial4port. It's this line:
    [FONT=courier new][SIZE=1]    if_z_ne_c    jmp  #receive     'abort if no stop bit   (TTA) (from serialMirror)[/SIZE][/FONT]
    Also with #receive1, 2, 3. That will make it behave more like the other fullDuplexSerial incarnations in that regard.
