Read variable frequency from UV detector board — Parallax Forums
ErlendErlend Posts: 612
edited 2013-11-01 19:45 in Propeller 1
One part of my (eternal...) project is to measure flame intensity. I've settled on using a UVtron tube, and the i/f bundled with it gives out a variable pulses/sec signal (handful of Hertz) propotional to the UV intensity - but in a Geiger kind of way I believe, meaning pulse spacing is not regular. I do not need high accuracy, but Propeller IO is tight now. Options are: 1) using one analog input channel (MCP3208) to measure the result through some RC filter, 2) using a digital input pin on the Prop together with som pulse count code, or 3) use some other brilliant other idea. For some reason I believe I havent cracked it yet.
Ideas?
Erlend
  • JonnyMacJonnyMac Posts: 9,836
    edited 2013-10-27 08:31
    It would be very easy to write a little PASM object that could measure the edge-to-edge timing of your signal and report it to the hub. Your program could treat this hub value as a regular variable and respond to it.
    edited 2013-10-27 16:07
    If you mean less than 100Hz by a hand full of Hz you could use one of the MCP input channels as a digital input as long as you are taking readings often enough (2x max pulse rate). Probably more accurate and certainly faster response than using an RC filter.
    edited 2013-10-27 16:13
    Another option would be to share the input pin the MCP uses by using the chip select signal to choose between them.
    edited 2013-10-27 16:42
    This might be a candidate for a cog counter, provided your main loop can come around at regular intervals to read the accumulation.
    [SIZE=1][FONT=courier new]
    PUB  PulseCounter(pin) | ticks
     ctra := % 01010 << 26 + pin      ' POSEDGE mode
     frqa := 1                          ' one count per edge
     ticks := cnt
     repeat
       waitcnt(ticks+=clkfreq)       ' synchronized wait one second
       showResult.Dec(phsa~)    ' capture accumulation and post-zero
       ' do other program stuff here, shy of one second[/FONT][/SIZE]
  • ErlendErlend Posts: 612
    edited 2013-10-28 04:05
    Let me be a bit more accurate:
    The signal is 5v pulses at varying intensity, but not in an orderly fashion; something like this: | | | || || | || | | | | || | ||||| |||| ||| | |||||| - which would convert to (averaged) intensity something like this: 2 .. 3 .. 3 .. 1 .. 1 .. 3 .. 5 .. 4 .. 5.
    The pulse intevals range from infinite to approx 0.05mS (20Hz). Some averaging is probably needed.
    I like the idea of trying out the cog counter, but then I'll need to understand how it works - an that is hard.
    @kwinn
    Can you explain the 'using ADC as digital input' a bit further?
    Erlend
    edited 2013-10-28 09:22
    Disillusion yourself of the notion that cog counter is hard to understand! :smile: In the posedge (negedge) mode it simply detects rising (falling) edges, and for each one it adds the frqa value (frqa:=1) to the accumulator, phsa. That's all there is to it. It does its thing while your program is off doing other tasks. To get a count over time, you have to have some means in place to read the content of phsa and reset it to zero at regular intervals.
    edited 2013-10-29 08:20
    I will dillusion myself and go ahead with the cog counter:smile:.
    Erlend
    edited 2013-10-29 12:59
    But counting pulses at megahertz speed maybe does not make much sense when all I'll ever count here are 1 - 20 pulses every second?
    edited 2013-10-29 16:14
    Erlend wrote: »
    @kwinn
    Erlend
    I hope that the 0.05mS (20Hz) is a typo and you really meant 0.05Seconds (20Hz). What I am posting is based on 0.05Seconds. The pulses are very short duration so you would need to stretch them out with a diode and RC circuit so the pulse duration is about 5mS. Then you need to read the ADC channel at least 40 times a second so no pulses are missed. Each reading is compared to the previous reading, and if it is higher than the one before a pulse has occurred. If the reading is lower or the same as before then there has not been a pulse. Of course you will need to have some minimum increase of the voltage to count it as a pulse or you will be counting fluctuations due to noise.
    On the whole I think Tracy's suggestion of using the counter is the best way to go if you have a pin to spare, but using the adc will also work
    edited 2013-10-29 20:49
    Erlend wrote: »
    The cog counter is just a specialized module that sits there sampling the input far, far faster than it needs to, but it only reacts and advances the count when the input changes. Is it a waste? Well, most programs spend a lot of time sitting in a loop, waiting. If you have concerns about power consumption, the cog counter could keep up with the UV-tron even with the prop running on a 5MHz clock, or maybe even RCslow if you have an external time reference.
    Input signal edges from the UV detector would have to be clean, noise-free. The counter modules sample so fast when clkfreq is high, that noise on the input signal edges can lead to multiple counts per edge. If that turns out to be a problem, then one of the other suggested techniques might work better.
    edited 2013-10-30 01:14
    @kwinn
    You are right, the 'milli' was a typo. The ADC object runs in a cog by itself, so it should come around fast enough, but I can see this solution will need some circuitry , which I'd like to avoid, so even if I have to spend another pin, I think I will go for the cog counter idea. Actually I have ideas for how that pin can be shared with an other input signal.
    @Tracy
    The pulse signal will be coming directly from a logic gate output, so it should be clean. And it is just me being irrational about it (hardware-emotional?) to worry that such a powerful counter has do do such a menial task. Power consuption is not a worry in this application.
  • jmgjmg Posts: 15,200
    edited 2013-10-31 12:50
    Erlend wrote: »
    You've paid for 16 counters, feel free to use them :)
    If the Logic gate is a schmitt with some form of low pass before it, you should be ok.
    If you want a rate, you will need to chose some timebase, and use maths or a table (guessing this is non-linear )
    With the Prop's 32 bit counters avoiding any overflow issues, you can use multiple timebase - eg display a 10 second rate, and also display a 100 or 1000 second background rate, if you want longer averages, or more precision.
    Erlend wrote: »
    I know what you mean. It seems like a trivial function for such a powerful bit of hardware but jmg is right, better to use it for something simple than leave it unused.
