Relatively thin, multi wire power cable available?
CuriousOne
Hello.
For a certain project, I need a relatively thin (<=1/4') power cable, which will have 4 insulated wires. The voltages applied will be: 230VAC and 350VDC. Current won't exceed 0.5A in each circuit.
Any ideas? I have searched a lot, and there are a lot of multi-wire cables available, but none of them lists high voltage compatibility.
http://www.ebay.com/itm/25-Coiled-Cable-4-Conductor-Cord-1-4-3-Retracted-Extends-to-25ft-NEW-/331039516679?pt=LH_DefaultDomain_0&hash=item4d137e2807
(coiled not required) but with guaranteed high voltage capabilities.
insulation thickness is going to be dependent on the maximum voltage
these are slightly larger but UL/CSA rated for 600V (you're 50V over using one with a 300V rating):
non-flexible 600V tray cable 18/4 is 0.310 inches (~5/16 inch)
http://www.wireandcabletogo.com/18-4C-THHN-PVC-Tray-Cable.html
flexible 600V 18/4 SEOOW Portable Cord is 0.387 inches (a bit over 3/8 inch)
http://www.wireandcabletogo.com/18-4-SEOOW-Portable-Cord-600V-UL-CSA.html
I see 600V .306" 4 conductor cable.
By the way, I have a roll of military surplus 22AWG silver clad teflon wire. What if I buy teflon or silicon tubing, and run 4 wires of that wire thru it?
I've checked for belden 8424, all places sell it in 100ft rolls, but i only need 15ft.
http://www.ebay.com/itm/8424-Non-Paired-Four-Conductor-Low-Impedance-Cable-/131029598670?pt=LH_DefaultDomain_0&hash=item1e81f901ce
Or you can buy it by the foot: http://www.markertek.com/Cables/Bulk-Wire-Cable/Bulk-Video-Cable/Belden/B8424.xhtml?BL-8424-500
I've had good luck getting all kinds of different cable and wire from Anixter.
traVis.
