S2 Radio-controlled navigation
Phil Pilgrim (PhiPi)
I don't know why no one has thought of this before, it's so obvious. Maybe they have, and I missed it. My apologies if so. Anyway, it's drop-dead easy to add an RC receiver to an S2 and control it with a transmitter. I added a cheapo ($25 for the full set: transmitter and receiver) 2.4 GHz HobbyKing radio to my S2, hidden inside. It connects to the hacker port via two channels -- one for throttle and one for steering -- which also powers the receiver. Here's a photo of the installation:
I adhered the receiver in place with double-stick foam tape. Connections to the hacker port were made with servo extension cables. Here's the code I used to control the S2 with the RC transmistter:
A full archive is attached.
Of course, you can add more channels if you like. The hacker port will support six total. A simple circuit that ORs all the channels together could conceivably multiplex all channels into one input. I checked my HobbyKing receiver, and there's just enough of a gap between pulses that a PASM program could demultiplex the channels again.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
STEERING = 0
THROTTLE = 1
THREV = 1200
THOFF = 1500
THFWD = 1800
STLFT = 1200
STCTR = 1500
STRGT = 1800
OBJ
pst : "Parallax Serial Terminal"
s2 : "S2"
PUB start | lftrgt, fwdrev
pst.start(9600)
s2.start
s2.start_motors
repeat
lftrgt := ((pulse_in(STEERING) #> STLFT <# STRGT) - STCTR) * 256 / constant(STRGT - STLFT)
lftrgt &= ||lftrgt > 20
fwdrev := ((pulse_in(THROTTLE) #> THREV <# THFWD) - THOFF) * 256 / constant(THFWD - THREV)
fwdrev &= ||fwdrev > 20
s2.move_now(fwdrev - lftrgt, fwdrev + lftrgt, 0, (||fwdrev #> ||lftrgt >> 1) >> 3, 1)
PUB pulse_in(pin) | t0, t1
waitpne(1 << pin, 1 << pin, 0)
waitpeq(1 << pin, 1 << pin, 0)
t0 := cnt
t1 := cnt
return (t1 - t0) / (clkfreq / 1_000_000)
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 STEERING = 0 THROTTLE = 1 THREV = 1200 THOFF = 1500 THFWD = 1800 STLFT = 1200 STCTR = 1500 STRGT = 1800 OBJ s2 : "S2" PUB start | lftrgt, fwdrev, plftrgt, pfwdrev s2.start s2.start_motors repeat lftrgt := ((pulse_in(STEERING) #> STLFT <# STRGT) - STCTR) * 256 / constant(STRGT - STLFT) lftrgt &= ||lftrgt > 20 fwdrev := ((pulse_in(THROTTLE) #> THREV <# THFWD) - THOFF) * 256 / constant(THFWD - THREV) fwdrev &= ||fwdrev > 20 if (lftrgt <> plftrgt or fwdrev <> pfwdrev) s2.move_now(fwdrev - lftrgt, fwdrev + lftrgt, 0, (||fwdrev #> ||lftrgt >> 1) >> 3, 1) plftrgt := lftrgt pfwdrev := fwdrev PUB pulse_in(pin) | t0, t1 waitpne(1 << pin, 1 << pin, 0) waitpeq(1 << pin, 1 << pin, 0) t0 := cnt waitpne(1 << pin, 1 << pin, 0) t1 := cnt return (t1 - t0) / (clkfreq / 1_000_000)-Phil
Funny, I am working on a few mods for my daughters S2 and was thinking about adding RC control. I hadn't bothered looking on the forums because I figured there would be several threads on it, so I was actually shocked when I read your post about it being the first.
I am hoping to be able to post the mods I am creating soon as I can't find any evidence of anyone doing what I am doing.
Thanks. I'm not sure mine is the first, though; and it would be strange if it were, since it's so obvious. It's just that I don't remember seeing any others.
http://www.youtube.com/watch?v=wIbW-zhpLjw
I think XBees are great for data, but they're a bit overkill for remote control apps, given the much cheaper prices of available 2.4 GHz RC setups. At one point, I was considering an external S2 plug-in board for RC receivers. But sticking the thing inside is much tidier and obviates the need for a separate PCB to interface to the S2's RS232 port. The only downside is that, without some OR gating, you need one pin for each RC channel.
The search linked to in my sig will allow even one character search terms.
Now I'll have to order an RC transmitter/receiver set and try it.
Rich, great videos on your Youtube channel. Love your Falcon hand glider. LONG ago, I bought a used Eipperformance Rogallo from Kitty Hawk Kites in Nag's Head NC with my paper route money. Best $140 I ever spent! I never went as high as you, maximum a hundred feet or so with that lame 4:1 glide ratio...!
I Tweaked Kye's pwm2_hbdengine to use with the S2 motor setup and modified your pulse_in routine to return 0 instead of 1500 when the aile/elev stick is centered. The pwm motor driver takes input from -400 to 400 for full reverse to full forward.
Con 'S2 RC receive/operate _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 Var Obj pwm : "s2motor_driver" Pub Main | aile, elev, left, right pwm.start(4_000) 'start S2 motor driver @ 4000 hert repeat aile := pulse_in(0) elev := pulse_in(1) left := elev - aile right := elev + aile pwm.leftrightduty(left, right) PUB pulse_in(pin) | t0, t1 waitpne(1 << pin, 1 << pin, 0) waitpeq(1 << pin, 1 << pin, 0) t0 := cnt waitpne(1 << pin, 1 << pin, 0) t1 := cnt return (t1 - t0) / (clkfreq / 1_000_000) - 1500Even if you do not have a rf receiver installed you can use this program to show the encoders output on the LED's by directly turning the wheels.
Con 'S2 RC receive/operate w/encoders triggering leds _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 Var Obj pwm : "s2motor_driver" Pub Main | aile, elev, left, right pwm.start(4_000) 'start S2 motor driver @ 4000 hertz cognew(@entry, 0) 'encoders/leds cog repeat aile := pulse_in(0) elev := pulse_in(1) left := elev - aile right := elev + aile pwm.leftrightduty (left, right) Pub pulse_in(pin) | t0, t1 waitpne(1 << pin, 1 << pin, 0) waitpeq(1 << pin, 1 << pin, 0) t0 := cnt waitpne(1 << pin, 1 << pin, 0) t1 := cnt return (t1 - t0) / (clkfreq / 1_000_000) - 1500 Dat org 0 entry andn outa, dirmask mov dira, dirmask mov time, cnt add time, period :loop test lftenc, ina wc if_c mov lights, #%1001_0000 if_nc mov lights, #%1010_0000 call #leds waitcnt time, period test rgtenc, ina wc if_c mov lights, #%1000_0100 if_nc mov lights, #%1000_1000 call #leds waitcnt time, period jmp #:loop leds mov cntr, #8 :loop shr lights, #1 wc muxc outa, data or outa, clk andn outa, clk djnz cntr, #:loop leds_ret ret lftenc long 1 << 13 rgtenc long 1 << 14 period long 8_000 data long 1 << 7 clk long 1 << 8 dirmask long $180 cntr res 1 lights res 1 time res 1
