Parallax GPS module to BS2 interface
The GPS module is not locking satellites quickly and if it does, it loses connections in a substantial time..
What may be the problem other than the powering issue.
Then the GPS module once locked is displaying junk data on the basic stamp editor (debugger).
Kindly help me with the way to proceed towards achieving the solution to this problem
Thank you for the time and appreciate ur help
1.Parallax GPS Receiver Module (#28146) ,designed in cooperation with Grand Idea Studio (www.grandideastudio.com).
2.I am testing it outdoors. i.e. on the roof terrace of the building.
3.As it is given in the GPS module datasheet, leaving the /RAW pin unconnected all others are connected as specified.
4.GPS is being powered from the microcontroller board. the vdd and gnd pins are connected to the breadboard on the development kit and from there it is getting powered.
5.It displays the wrong information regarding the latitude, longitude and the year..so on..
6.I am running the sample program that has been given in the datasheet of gps_manual_2.0_parallelax.
Can u please suggest me the ways to go about it and the mistakes that i am doing as it is very urgent and if possible please give me a source of an alternate code to test it.
Thanks again
This is what i am recieving as of now.
I will try running it again by making the RAW pin high.
btw since RAW pin is internally pulled high, do i have to connect it to VDD or to GND externally because i do not want to lose the only one GPS module that i have.
Thanks again.
Thank you so much Chris Savage, appreciate your help.
I also request you to give me further inputs if you find anything wrong from here.
Best regards!!
It seems working and i hereby put the screenshot of the result and also the snaps of the GPS module, since you asked.
This was all possible because of you.Please help me in future also if i face problems like these.
Best regards.
