Ping)))Dar "1 Scan Only, Please"
Hello,
I've gotten the Ping)))Dar program to run (on my Boe-Bot) as described but am still having a few issues.
How do I modify the code so the Ping)))Dar only scans once and then moves forward toward object.
My boebot goes through the scanning sequence, identifyies object, then moves forward maybe several inches. It then stops, goes through the scanning process again, moves forward another couple of inches, stops, scans again, etc.
Again, I want it to accept the initial scan and move forward to infinity.
Here's the code:
Here's the code:
' -----[ Title ]-------------------------------------------------------------- ' Smart Sensors and Applications - GoToClosestObject.bs2 ' Sweep Ping))) Ultrasonic Rangefinder across 180-degrees and find the closest ' object. Then calculate and execute the turn required to face the object. ' Travel forward until the object is less than or equal to 5 cm from the front ' of the rangefinder. ' IMPORTANT: This program has several constants that have to be tuned before ' it will work right. Follow the instructions in Smart Sensors ' and Applications, Chapter 8, Activity #4 and #5 before you run ' this program! ' {$STAMP BS2} ' Target device = BASIC Stamp 2 ' {$PBASIC 2.5} ' Language = PBASIC 2.5 ' -----[ I/O Definitions ]---------------------------------------------------- ' Ping))) Ultrasonc Rangefinder and Mounting Bracket PingServo PIN 14 ' Servo that directs Ping))) snsr Ping PIN 1 ' Ping))) sensor signal pin ' Boe-Bot servo pins (Left and right are from driver's seat perspective.) BotServoLeft PIN 13 ' Left drive servo BotServoRight PIN 12 ' Right drive servo StartLED PIN 0 ' display start delay ' -----[ Constants ]---------------------------------------------------------- ' Ping))) mounting bracket constants LimitLeft CON 1189 ' Bracket 90-degrees Left LimitRight CON 286 ' Bracket 90-degrees Right Limits CON LimitLeft + limitRight 'this added from Forum Center CON 750 ' Center/0-degree pulse duration Increment CON 15 ' Increment for pulse sweeping MinSweep CON 40 ' Pulses -> 90-degree right ' Boe-Bot continuous rotation servo control constants FwdLeftFast CON 817 ' Fast settings - straight ahead FwdRightFast CON 650 RotateRight CON 763 ' Boe-Bot rotate right pulse RotateLeft CON 740 ' Boe-Bot rotate left pulse BtwnPulses CON 20 ' ms between servo pulses ' Ping))) Ultrasonic Rangefinder constants CmConstant CON 2260 ' Echo time -> cm with ** SinCosTo256 CON 517 ' For */ -127..127 -> -256..256 Ms20 CON 330 ' 20 ms worth of cm ' MSB sign (twos complement) Negative CON 1 ' Negative sign (bit-15) Positive CON 0 ' Positive sign (bit-15) ' Ping and turning axis geometry PingDirToAngle CON 8454 ' Servo pulse to angle ** con PingAxleOffset CON 7 ' 7 cm between ping))) and axis ' -----[ Variables ]---------------------------------------------------------- time VAR Word ' Ping))) echo time pingDir VAR Word ' Pulse duration -> direction pingRev VAR Word ' Pulse duration -> direction for reversed servo ' added from Forum x VAR Word ' x coordinate y VAR Word ' y coordinate distance VAR Time ' Object centimeter distance markDir VAR y ' Pulse points to closest object rightMark VAR x ' Pulse to object's right side leftMark VAR pingDir ' Pulse to object's left side pulses VAR x ' +/- brads to turn toward object PrevDist VAR Byte ' Previous distance measurement angle VAR Byte ' Servo angle from right in brads counter VAR angle ' Loop counter minDist VAR angle ' Minimum distance measurement sweepInc VAR Nib ' Increment for servo sweep sweepDir VAR Bit ' Increment/decrement pingDir xSign VAR Bit ' Stores sign of x variable ySign VAR xSign ' Stores sign of x variable pSign VAR Bit ' Sign of pulses variable edgesFound VAR Bit ' Navigation flag temp VAR Byte ' -----[ Initialization ]----------------------------------------------------- ' -----[ EEPROM Data ]----------------------------------------------------- RunStatus DATA $00 ' run status ' -----[ Initialization ]-------------------------------------------------- Reset: READ RunStatus, temp ' read current status temp = ~temp ' invert status WRITE RunStatus, temp ' save for next reset IF (temp > 0) THEN END ' run now? Start_Delay: HIGH StartLED ' show active PAUSE 5000 ' start delay LOW StartLED ' LED off ' following from Forum pingDir = LimitRight ' Start servo at 0-degrees FOR counter = 1 TO 40 ' Initialize servo position 'PULSOUT PingServo, pingDir ' Forum: removed & replaced by next 2 lines pingRev = Limits - pingDir PULSOUT PingServo, pingRev PAUSE 20 NEXT sweepInc = Increment ' Set the sweep increment ' -----[ Main Routine ]------------------------------------------------------- GOSUB Get_Ping_Cm ' First distance measurement DO UNTIL distance <= 5 ' Repeat until distance <= 5 cm edgesFound = 0 ' Clear edges found flag DO UNTIL edgesFound = 1 ' Repeat until edges found = 1 GOSUB Face_Closest_Object ' Find & face closest object LOOP GOSUB Get_Ping_Cm ' Get current distance DO UNTIL distance <= 5 ' Drive toward object prevDist = distance MAX 255 ' Current distance -> previous GOSUB Get_Ping_Cm ' Get new distance PULSOUT BotServoLeft, FwdLeftFast ' Boe-Bot forward PULSOUT BotServoRight, FwdRightFast PAUSE BtwnPulses - (distance / Ms20) ' 20 ms pause between pulses IF distance >= prevDist + 5 THEN EXIT ' Exit if distance increasing LOOP LOOP ' Main routine's outermost loop END ' -----[ Subroutines - BoeBot_Turn_Brads ]----------------------------------- ' Boe-Bot turns a certain number of binary radians to face an object. BoeBot_Turn_Brads: IF pSign = Positive THEN FOR counter = 0 TO ABS(pulses) PULSOUT BotServoLeft, RotateRight PULSOUT BotServoRight, RotateRight PAUSE BtwnPulses - (distance / Ms20) NEXT ELSE FOR counter = 0 TO ABS(pulses) PULSOUT BotServoLeft, RotateLeft PULSOUT BotServoRight, RotateLeft PAUSE BtwnPulses - (distance / Ms20) NEXT ENDIF RETURN ' -----[ Subroutines - Face_Closest_Object ]---------------------------------- ' Scan for closest object using a Ping))) rangefinder mounted on a standard ' servo. Locate the middle fo the object, and turn Boe-Bot to face it. Face_Closest_Object: ' Initialize sweep increment. sweepInc = Increment ' Start Servo rotated to the far right. pingDir = LimitRight GOSUB Point_At_PingDir ' Make minDist large and sweepDir positive (0). Single_Sweep sweeps ' left -> right while measuring object distances and stores the direction ' of the closest object in markDir. minDist = 65535 sweepDir = Positive GOSUB Single_Sweep ' Point the servo in the direction of the closest distance measurement. pingDir = markDir GOSUB Point_At_PingDir ' Scan to find object's right side. GOSUB Find_Right_Side IF edgesFound = 0 THEN RETURN ' Point the servo in the direction of the closest distance measurement. pingDir = markDir GOSUB Point_At_PingDir ' Scan to find object's right side. GOSUB Find_Left_Side IF edgesFound = 0 THEN RETURN ' Average the angles to the object's left and right sides. That's the ' middle of the object. Point rangefinder in that direction. pingDir = leftMark + rightMark / 2 GOSUB Point_At_PingDir ' At this point, the Ping))) should be pointing directly at the closest ' object. ' Calculate the angle to the object's angle in brads, and turn the ' Boe-Bot to face that angle. GOSUB Turn_Angle_Adjust GOSUB BoeBot_Turn_Brads ' Face Ping))) rangefinder straight ahead. pingDir = Center GOSUB Point_At_PingDir RETURN ' -----[ Subroutines - Find_Left_Side ]--------------------------------------- ' Scan left until the measured distance is 10 cm beyond the closest distance, ' which is assumed to mean the object's side has been found. ' If the object's side has been found within the 180-degree field of vision, ' set edgesFound = 1 and store the pulse duration (pingDir) at which the ' object was found in the leftMark variable. ' If the side was not found by the 180-degree point in the scan, rotate the ' Boe-Bot until the edge is found, and then set edgesFound to 0 signifying ' that the scan will have to be repeated because the Boe-Bot rotated ' to find the side, which would otherwise cause the markDir variable to ' store an incorrect value. Find_Left_Side: sweepDir = Positive distance = minDist sweepInc = 1 DO UNTIL distance > minDist + 10 GOSUB Sweep_Increment GOSUB Get_Ping_Cm IF pingDir >= LimitLeft - 10 THEN pingDir = LimitLeft - 50 GOSUB Point_At_PingDir DO UNTIL distance > minDist + 10 PULSOUT BotServoLeft, RotateLeft PULSOUT BotServoRight, RotateLeft GOSUB Get_Ping_Cm PAUSE 20 LOOP edgesFound = 0 RETURN ENDIF LOOP leftMark = pingDir edgesFound = 1 RETURN ' -----[ Subroutines - Find_Right_Side ]-------------------------------------- ' Mirror image of Find_Left_Side. Find_Right_Side: sweepDir = Negative distance = minDist sweepInc = 1 DO UNTIL distance > minDist + 10 GOSUB Sweep_Increment GOSUB Get_Ping_Cm IF pingDir <= LimitRight + 10 THEN pingDir = LimitRight + 50 GOSUB Point_At_PingDir DO UNTIL distance > minDist + 10 PULSOUT BotServoLeft, RotateRight PULSOUT BotServoRight, RotateRight GOSUB Get_Ping_Cm PAUSE 20 LOOP edgesFound = 0 RETURN ENDIF LOOP rightMark = pingDir edgesFound = 1 RETURN ' -----[ Subroutine - Get_Ping_Cm ]------------------------------------------- ' Gets Ping))) rangefinder measurement and converts time to centimeters. ' Distance may be declared as time to save variable space. Get_Ping_Cm: PULSOUT Ping, 5 PULSIN Ping, 1, time distance = time ** CmConstant RETURN ' -----[ Subroutines - Point_At_PingDir ]------------------------------------- ' Points servo mounted Ping))) rangefinder at an angle determined by the ' value of the pingDir variable. Point_At_PingDir: FOR counter = 0 TO MinSweep ' PULSOUT PingServo, pingDir ' Forum: removed & replaced by next 2 lines pingRev = Limits - pingDir PULSOUT PingServo, pingRev PAUSE BtwnPulses NEXT RETURN ' -----[ Subroutine - Polar_To_Cartesian ]------------------------------------ ' Calculates x and y (Cartesian coordinates) given distance and angle ' (polar coordinates). Polar_To_Cartesian: ' Calculate left/right component. x = COS angle ' Polar to Cartesian xSign = x.BIT15 ' Store sign bit x = ABS(x) */ SinCOsTo256 ' Polar to Cartesian continued x = distance */ x IF xSign = negative THEN x = -x ' Correct sign with sign bit ' Calculate straight ahead component. y = SIN angle ' Polar to Cartesian ySign = y.BIT15 ' Store sign bit y = ABS(y) */ SinCOsTo256 ' Polar to Cartesian continued y = distance */ y IF ySign = negative THEN y = -y ' Correct sign with sign bit RETURN ' -----[ Subroutines - Single_Sweep ]----------------------------------------- ' Do one sweep, and find the closest distance measurement and the ' pulse value that points the servo in that direction. Single_Sweep: DO UNTIL pingDir >= LimitLeft GOSUB Sweep_Increment GOSUB Get_Ping_Cm IF distance < minDist THEN minDist = distance markDir = pingDir ENDIF LOOP RETURN ' -----[ Subroutine - Sweep_Increment ]--------------------------------------- ' Increment/decrement the position of the servo that directs the Ping))) ' rangefinder. When pingDir goes outside either LimitRight or LimitLeft, ' the sweep direction toggles. Sweep_Increment: ' Change sweepDir for adding/subtracting increment if at rotation limit. IF pingDir <= LimitRight THEN sweepDir = Positive ELSEIF pingDir >= LimitLeft THEN sweepDir = Negative ENDIF ' Add/subtract increment to/from pingDir. IF sweepDir = negative THEN pingDir = pingDir - sweepInc ELSEIF sweepDir = Positive THEN pingDir = pingDir + sweepInc ENDIF ' Send positioning pulse to Ping))) Mounting Bracket servo. ' PULSOUT PingServo, pingDir ' Forum: removed & replaced by next 2 lines pingRev = Limits - pingDir PULSOUT PingServo, pingRev RETURN ' -----[ Subroutines - Turn_Angle_Adjust ]------------------------------------ ' Adjusts required turn angle based on 7 mm offset of Ping))) rangefinder from ' Boe-Bot's turning axis. Turn_Angle_Adjust: ' Get the object's distance at its center. GOSUB Get_Ping_Cm ' Position servo & calculate angle from far-right in brads. angle = pingDir - 250 ** PingDirToAngle GOSUB Polar_To_Cartesian ' Add distance between Ping))) and center of Boe-Bot axis. y = y + PingAxleOffset ' Recalculate the turning angle with respect to Boe-Bot's turning axis. angle = x ATN y pulses = 64 - angle pSign = pulses.BIT15 RETURN
I would suggest making sure your batteries are fresh. The servos can draw a significant amount of current causing the BOE to reset, restarting the program. I had a similar problem with Ping roaming and it took me a bit to determine the batteries were weak.
Try replacing the batteries and if the issue persists, we have another problem to sort out.
Good Luck!
Amanda
Change this section:
To this:
I just removed all the distance checks and calculations once the robot starts moving toward the target. The robot will just keep going without looking where it's going anymore.
