Cannot access Spinneret from internet
I have set up the Spinneret and router with port forwarding as per "Hello World", "GETing to the Server" and "Making your Spinneret Internet Accessibble". It works very stably on the internal home network. However, when I try and access from the internet I get the following error messages a) From Firefox"connection was reset" b) From Spinneret PST connection * Timeout * Any pointers or ideas on howI can troubleshoot this? Many thanks in advance.
http://whatismyip.com
Then you need to set up your router to forward incoming requests to the port you've assigned the Spinneret to the Spinneret's local network address.
Change it to...
..or play with the values until you find one that works best.
I'n trying to retire HttpServer. Please check out the newer stuff.
