RN-42 connection trouble
Hello,
I have bought a RN-42 module (http://www.parallax.com/product/30086) in order to transmit GPS date into a Nikon camera (as described here : http://www.diyphotography.net/build-a-bluetooth-gps-unit-for-nikon).
For now, I have just connected the RN-42 to a USB port for the 5V supply.
I have configured the RN-42 via bluetooth with TeraTerm or RealTerm.
I managed to connect the GPS with the RN-42 using the following settings:
RN-42 is in auto-connect mode with the remote address of the GPS stored. I also enabled the bonding option.
Both, GPS and RN-42, have the same pairing code.
Here is the problem : it seems that the configuration is not saved correctly or disappeared somehow. Just after the configuration, I can connect the 2 devices. But after a while (when I disconnect a module for example), the connection is not working anymore.
I do not really understand where is the mistake (I'm sure there is one ...).
I'm a great beginner in this kind of stuff, so I apologize if the answer seemed obvious.
Thanks for the help.
Jul.
Jul.
Welcome to the forums! I had an issue with some test code where I was sure the RN-42 stopped responding but then 60 seconds later data resumed. The test code was just sending a value and incrementing, etc. Once it hit the escape sequence character (Decimal 36 I think) it stopped waiting for the the next character in the escape sequence. There are internal timers that affect all of this. I believe the window by default is 60 seconds to be able to initiate command mode. If you send the escape sequence character I believe it will wait for that amount of time before aborting. You may have to change to connecting and going immediately into fast-data mode.
With my RN-42, i don't make program. I just want to connect a GPS with my Nikon camera.
The Rn-42 should be connected to the camera by cable and retrieve GPS position by bluetooth
To do that, I have just send into the module some basic instruction (as described in this document : http://parallax.com/downloads/rn-42-bluetooth-module-advanced-users-manual).
Maybe I shouldn't configure the module via Bluetooth ?
Sorry again, if I didn't understand your answer.
Jul
I just connect the module to a USB cable in order to bring the power to the RN-42. There are only 2 wires used in the USB cable (power and ground). For now, I just try to connect by bluetooth, the GPS and the RN-42 module, that's all.
To be remotly configured, you have to send to the module this string of character : $$$ within 60s after connecting the module. But, it is in configuration mode, you can see the LED blink in a special sequence. So, I didn't see that happen when I tried to connect it with my GPS. Moreover, the GPS only send some NMEA sentence of this kind :
$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
I will try with another GPS module to see if there is trouble with the first GPS receiver.
Anyway, thanks again.
Jul.
Jul
