NTSC — Parallax Forums
NTSC
rjo__rjo__ Posts: 2,114
edited 2013-11-19 18:58 in Propeller 2
At this point there is so much I don't know that I have some difficulty formulating a reasonable question:)
I think I have one.
I have gone back through this forum twice. If it is here, I don't see it.
I have some nice NTSC sample code from Tubular, Potatohead, Baggers etc.
What I don't see is a full NTSC driver for a de0... I don't care if it displays black, with a little window for actual data.
I have the 256x192x8bit_grey displaying very nicely... but it fills the whole screen. How do I get it to just display the 256x192 in the middle of a full NTSC screen?
Rich
  • TubularTubular Posts: 4,768
    edited 2013-10-21 15:25
    Hi Rich
    I don't have time to do this right at the moment, but what you need to do is reduce the Video circuit "clocks per pixel" from 9 to say 3, and then compensate 3x to keep the timing the same overall. An easy way to start might be to repeat the same data three times (resulting in 3 compacted images across the screen), or replace the first and third with black, for instance. Then move on to modifying the vertical in a similar way
  • rjo__rjo__ Posts: 2,114
    edited 2013-10-21 15:47
    Tubular,
    Thanks.
    That's as much help as I actually wanted unless someone had the code ready to go.
    I think I have tried everything you suggested... but who knows for sure?
    Happy coding
    Rich
  • ozpropdevozpropdev Posts: 2,793
    edited 2013-10-21 18:05
    Hi Rich
    Here is example of what Tubular was talking about.
    In this example of VGA 800x600 I am placing 6 separate panels within that window.
    Each panel is 256 pixels wide with 2 16 pixel black edges.
    The key is that the total clock count is 800 (for 1 clock per pixel)
    As long as the clocks add up to the correct width of your video mode, you can position your image where you want.
    Here is a sample of my pixel output code
    send_pixels		call	#sync			'do horizontal sync
    			waitvid	edge,#0
    			waitvid	mode1,char_color
    			waitvid	mode2,char_color4
    			waitvid	mode3,char_color2
    			waitvid	edge,#0
    edge			long	pixel_base << 24 + $7 << 20 + 1 << 13 +	16
    mode1			long	pixel_base << 24 + $7 << 20 + 1 << 13 +	256
    mode2			long	32 << 24 + $7 << 20 + 1 << 13 +	256 '288
    mode3			long	(pixel_base+8)  << 24 + $7 << 20 + 1 << 13 + 256
    Hope this helps
    Cheers
    Brian
    1024 x 613 - 68K
  • AribaAriba Posts: 2,694
    edited 2013-10-21 20:39
    Here are two of my PAL drivers changed to NTSC and adapted to the new clkfreq.
    Because rjo_ likes grayscale, the first one is a 256x100 grayscale driver.
    The second is a modified version of Baggers Fire demo (256x100 with colours).
    Andy
    edited 2013-10-21 21:48
    Andy,
    Can you add the fire.bin.pal.bin file it's looking for? Look forward to seeing that fire.
    thanks
    Lachlan
    edited 2013-10-21 22:03
    Tubular wrote: »
    Andy,
    thanks
    Lachlan
    Okay it's added to the prevoius post
    Enjoy
    Andy
    edited 2013-10-21 22:31
    Thanks for that file Andy
    That fire effect is brilliant. Thanks Baggers!.
    I have a P2 WS2812B driver and many 150 pixel long led strips coming... will be interesting to scale it up
    cheers
    Lachlan
  • BaggersBaggers Posts: 3,019
    edited 2013-11-17 05:59
    No probs Tubular :D
    I missed this post, glad I checked it out :)
    Golly,
    This makes me look ungrateful. In my defense, this conversation was continued in a different thread.
    Just as an update, I have NTSC working as I want it… but the only way that I can use it with a camera is to put the camera first, fill a buffer… and then display it…. which means that
    I would have to reboot to take another picture.
    Multithreading is a no brainer… once you look at it carefully, but making NTSC multithreading in 8 bit gray scale would require me to actually understand all of the code I am using… and … and …. nope:)
    Rich
