De-springing 27800 joystick
Hello,
I recently purchased a 27800 two axis analog joystick, and I would really like to remove the spring so both axes retain their position. I read in another thread about a little piston that can be removed. Has anyone tried this before? I desoldered the joystick from the pcb, but it didn't look too easily accessible. Where is the spring assembly? Thanks very much!
http://www.parallax.com/product/27800
I followed your instructions and bent back the tabs on the metal case. I thought that would dismantle the axes, but only the bottom
is removed. All the mechanics of the joystick stay in place. The plastic bottom holds a white spring loaded piston that can be removed
by unlocking the little tabs on each side. Under the piston is a coil spring. After taking out the spring, I put the piston back (that might not
be necessary) and replaced the bottom. Now the joystick position stays where I left it!
