HB-25 motor controller , can you run it at 24 volts — Parallax Forums
jdoleckijdolecki Posts: 726
edited 2013-10-21 12:34 in Robotics
Can you run the HB-25 at 24 volts
Parallax spec sheet says max of 18 volts but the chip manfacture (stmicro) says max 40 volts for that chip?
  • W9GFOW9GFO Posts: 4,010
    edited 2013-10-21 06:03
    The max voltage is 16V, not 18V.
    See this thread; http://forums.parallax.com/showthread.php/123559-HB-25-max-voltage
  • ercoerco Posts: 20,257
    edited 2013-10-21 08:49
    Just once. :)
  • jdoleckijdolecki Posts: 726
    edited 2013-10-21 09:02
    The spec on the chip from ST Micro says max is 41 volts.
    I see parallax says they never ran it that high.
    Is there a schamtic for the HB-25 anywere?
    Is ther any other component that wont handle 24 v? The fan?
    What about the Current Sense on the chip I dont see were it is brought out to any connection on the HB-25?
    edited 2013-10-21 10:08
    jdolecki wrote: »
    There is a small microcontroller on the HB-25 which converts the servo pulse values into PWM to drive the H-Bridge. This MCU is powered via a small regulator on the PCB which imposes the VIN limitation.
  • rjo__rjo__ Posts: 2,114
    There is also a fuse that would have to be changed out. I think it would be worth looking at. About 6 months ago, I looked around for 24V controllers and none of them is as nice as the HB-25. I bought one, which I thought looked best. It does work but is a pain to use and has little(and sometimes BIG) annoying issues with every type of control logic.
    I know there is a stockpile of HB-25s, but there really is a need for a bigger brother.
