3.2" Touch Screen W/SD Card Holder under $20.00
NWCCTV
Is this a good deal? I picked one up just because it was under $20.00, Can it be useful with Prop projects?
Also a 2.4" here.
Temp/Humidity Sensor for $1.99
Also a 2.4" here.
Twice as many pixels (480x320), same footprint, but a bit more expensive: http://www.ebay.co.uk/itm/New-3-2-TFT-LCD-Display-480-X-320-Module-ILI9481-Driver-IC-touch-panel-PCB-/271241999764?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item3f27487594
(I've got one, but haven't got it working yet BTW)
2.4" module (ILI9341, 320x240, SPI interface), far fewer pins needed to drive, no touch panel: http://www.ebay.co.uk/itm/2-2-Inch-SPI-TFT-LCD-Serial-Port-Module-Display-ILI9341-5V-3-3V-New-/200972663189?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item2ecae77995
I have one and got it working, but not yet on Prop.
Sure it can! And it is great to see the prices continuing to come down.
http://forums.parallax.com/showthread.php/137266-Propeller-GUI-touchscreen-and-full-color-display
Jeff
http://www.rayslogic.com/
I stumbled on the touchscreen displays on the parallax store and it looks like a great product. My question is, can I easily input a live video feed (RCA) to the display and use the touchscreen to support a menu function and/or the ability to switch video inputs? Any help is appreciated. I am not a master at code in any respect, as I am more hardware-minded, but I have BASIC Stamp experience and am willing to learn.
For those who care, this is for an FPV application off of my rc drone. I want to create a wearable peripheral video display for monitoring purposes.
Jake Warren.
BUT
If you use a standard NTSC LCD monitor, you can use Phil's "propeller backpack" to overlay menu's etc on top of the video feed. You could get a separate resistive touch screen and add that to the NTSC display.
