Welding with transistors! EPC eGaN FETs
Switching dozens of amps at a few nano-seconds. New Enhanced Gallium Nitride FETs from EPC.
http://epc-co.com/epc/Products/eGaNFETs.aspx
Check out this amazing video, welding with transistors:
https://www.youtube.com/watch?v=2GNrxOcolNQ
I have to get me some of these:)
switching time... The gate drive requirements are going to be interesting (significant leakage). They bring the substrate out
as a pin since its a lateral flow device (3 milliohms!!). Look to be nice devices for direct 5V logic use due to the lower input
capacitances than silicon devices of low Rds(on) - they would PWM at 50kHz without needing more than a microcontroller
pin to drive the gate I think. Bootstrapped hi-side switch will be interesting due to the large gate leakage
[BTW you can get a nice arc out of a solar panel if its 30V or more, PV panels are intrinsically current sources
and hold an arc nicely]
That's cool but real real men do their welding with explosives: https://www.youtube.com/watch?v=CtRroe_Qpuo
Can't find a video of welding boiler tubes with explosives as they do.
Peter,
You guys don't ask much.
Is there any advantage to these little welding transistors then? D class audio power amps maybe?
