Need help in finding average ,voltage reading using ADC 831 with basic stamp code — Parallax Forums
mogu93mogu93 Posts: 22
edited 2013-10-20 07:25 in BASIC Stamp
This is my code ,where I take 4 reading ,and average reading .I need helping in reading average reading of the voltages using a adc also shift in the reading and looping it . I don't know if my code is correct . THANKS! :DD ' {$STAMP BS2}
' {$PBASIC 2.5}
[ Program Description ]
' This program demonstrates reading a variable voltage with an ADC0831
' analog-to-digital converter chip. This program uses a Vref input of
' 5.000 volts (Vdd) for a bit resolution of 19.6 millivolts.
[ I/O Definitions ]
CS PIN 0 ' chip select (ADC0831.1)
Clock PIN 1 ' clock (ADC0831.7)
DataIn PIN 2 ' data (ADC0831.6)
[ Constants ]
Cnts2Mv CON $139C ' x 19.6 (to millivolts)
[ Variables ]
result VAR Byte ' result of conversion
mVolts VAR Word ' millivolts
mVolts1 VAR Word ' millivolts
mVolts2 VAR Word ' millivolts
mVolts3 VAR Word ' millivolts
mVolts4 VAR Word
mVolts5 VAR Word
mVolts9 VAR Word
[ Initialization ]
Reset:
DEBUG CLS, ' create report screen
"ADC.... ", CR,
"volts... "
[ Program Code ]
Main:
DO
GOSUB Read_0831 ' read the ADC
mVolts1 = result */ Cnts2Mv ' convert to millivolts
DEBUG HOME, ' report
CRSRXY, 9, 0, DEC result, CLREOL,
CRSRXY, 9, 1, DEC mVolts1 DIG 3,
".", DEC3 mVolts1
PAUSE 1000
mVolts2 = result */ Cnts2Mv ' convert to millivolts
CRSRXY, 9, 1, DEC mVolts2 DIG 3,
".", DEC3 mVolts2
PAUSE 1000
mVolts3 = result */ Cnts2Mv ' convert to millivolts
CRSRXY, 9, 1, DEC mVolts3 DIG 3,
".", DEC3 mVolts3
PAUSE 1000
mVolts4 = result */ Cnts2Mv ' convert to millivolts
CRSRXY, 9, 1, DEC mVolts4 DIG 3,
".", DEC3 mVolts4
PAUSE 1000
mVolts = (mVolts1+mVolts2+mVolts3+mVolts4)/4' convert to millivolts
CRSRXY, 9, 1, DEC mVolts DIG 3,
".", DEC3 mVolts
PAUSE 1000
mVolts5 = result */ Cnts2Mv ' convert to millivolts
mVolts1=mVolts2
mVolts2=mVolts3
mVolts3=mVolts4
mVolts9 = (mVolts5+mVolts1+mVolts2+mVolts3)/4' convert to millivolts
CRSRXY, 9, 1, DEC mVolts9 DIG 3,
".", DEC3 mVolts9
PAUSE 3000
LOOP
[ Subroutines ]
Read_0831:
LOW CS ' enable ADC
SHIFTIN DataIn, Clock, MSBPOST, [result\9] ' read ADC
HIGH CS ' disable ADC
RETURN
  • Francis160791Francis160791 Posts: 28
    edited 2013-10-18 02:03
    this seem so hard......
    edited 2013-10-18 07:02
    Francis160791,
    Your code looks good, the only thing I really did was to change how you dealt with consecutive ADC reads towards the bottom ....
    "Bump the oldest ADC value out in preparation of inserting the new value"
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' -----[ Program Description ]---------------------------------------------
    ' -----[ I/O Definitions ]-------------------------------------------------
    ' -----[ Constants ]-------------------------------------------------------
    ' -----[ Variables ]-------------------------------------------------------
    mVolts4 VAR Word
    ' -----[ Initialization ]--------------------------------------------------
    Reset:
    "ADC.... ", CR,
    "volts... "
    ' -----[ Program Code ]----------------------------------------------------
    Main:
    '--------------------------------¦ Initialize ¦---------------------------
    ' Read the first 3 consecutive ADC values here
    ".", DEC3 mVolts1
    PAUSE 1000
    ".", DEC3 mVolts2
    PAUSE 1000
    ".", DEC3 mVolts3
    PAUSE 1000
    '--------------------------------¦ Main Loop ¦----------------------------
    'Perpetually read the 4th ADC value here in this loop
    DO
    '--------------------------------¦ Average ¦------------------------------
    'Average the 4 ADC results together and display
       ".", DEC3 mVolts
       PAUSE 3000
    '------------------------¦ Bump the oldest ADC value out ¦----------------
       mVolts1=mVolts2
       mVolts2=mVolts3
       mVolts3=mVolts4
    LOOP
    Read_0831:
    '--------------------------------¦ Read_0831 ¦----------------------------
    LOW CS ' enable ADC
    RETURN
  • mogu93mogu93 Posts: 22
    edited 2013-10-18 20:10
    thanks for your help ! :smile::tongue::lol:
    but how is the code work man ?
