' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ I/O Definitions ]-------------------------------------------------
TX PIN 15 ' serial output to LCD
' -----[ Constants ]-------------------------------------------------------
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
T9600 CON 84
T19K2 CON 32
#CASE BS2SX, BS2P
T2400 CON 1021
T9600 CON 240
T19K2 CON 110
#CASE BS2PX
T2400 CON 1646
T9600 CON 396
T19K2 CON 188
#ENDSELECT
LcdBaud CON T19K2
LcdBkSpc CON $08 ' move cursor left
LcdRt CON $09 ' move cursor right
LcdLF CON $0A ' move cursor down 1 line
LcdCls CON $0C ' clear LCD (use PAUSE 5 after)
LcdCR CON $0D ' move pos 0 of next line
LcdBLon CON $11 ' backlight on
LcdBLoff CON $12 ' backlight off
LcdOff CON $15 ' LCD off
LcdOn1 CON $16 ' LCD on; cursor off, blink off
LcdOn2 CON $17 ' LCD on; cursor off, blink on
LcdOn3 CON $18 ' LCD on; cursor on, blink off
LcdOn4 CON $19 ' LCD on; cursor on, blink on
LcdLine1 CON $80 ' move to line 1, column 0
LcdLine2 CON $94 ' move to line 2, column 0
LcdCC0 CON $F8 ' define custom char 0
LcdCC1 CON $F9 ' define custom char 1
LcdCC2 CON $FA ' define custom char 2
LcdCC3 CON $FB ' define custom char 3
LcdCC4 CON $FC ' define custom char 4
LcdCC5 CON $FD ' define custom char 5
LcdCC6 CON $FE ' define custom char 6
LcdCC7 CON $FF ' define custom char 7
DIR0 = 0 'pin to read left saw or X1X
DIR1 = 0 'pin to read right saw or X2X
DIR2 = 0 'Pin to read xauger or X3X
DIR3 = 0 'pin to read pot for alarms on saws or A1A and is also A2A
DIR4 = 0 'pin to read pot for alarm on xauger or A2A
DIR5 = 0 'pin to turn on buzzer connected to blue pulsing buzzer through transistor
DIR6 = 0 'pin to turn on led for alarm
DIR7 = 0 ' pin saved to read GROUND SPEED at later date
DIR8 = 0 '
DIR9 = 0 '
DIR10 = 0 '
DIR11 = 0 '
DIR12 = 0 '
DIR13 = 0 '
DIR14 = 0 '
DIR15 = 0 '
' -----[ Variables ]-------------------------------------------------------
X1X VAR Word ' variable tag for rpm value of Left saw
X2X VAR Word ' variable tag for rpm value of right saw
X3X VAR Word ' variable tag for rpm value of xauger
A1A VAR Word ' variable tag for alarm set point of BOTH saws
A2A VAR Word ' variable tag for alarm set point of auger
A3A VAR Word ' variable tag for alarm set point of right saw BUT REALLY EQUAL TO A1A
ALARM VAR Word ' variable tag to turn on alarm
' -----[ Initialization ]--------------------------------------------------
Reset:
HIGH TX ' setup serial output pin
PAUSE 100 ' allow LCD to initialize
' -----[ Program Code ]----------------------------------------------------
' Clear the display and remove cursor and blinking attributes.
Main:
SEROUT TX, LcdBaud, [LcdBLon, LcdOn1, LcdCls]
PAUSE 100
GOSUB Pot_SAWS ' GET pot for alarms on saws
GOSUB Pot_XAUGER ' GET pot for alarm on Xauger
GOSUB X1X_SPEED 'GET SPEED OF LEFT SAW WITH COUNT
GOSUB X2X_SPEED 'GET SPEED OF RIGHT SAW WITH COUNT
GOSUB X3X_SPEED 'GE SPEED OF XAUGER WITH COUNT
GOSUB Compare ' compare rpms to alarm set points
'gosub Set_ALARMS ' did this in compare
GOSUB Update_LCD ' refreshes lcd display
GOTO main '
' -----[ Subroutines ]-----------------------------------------------------
Update_LCD:
SEROUT TX, LcdBaud, [LcdLine1, " ", DEC3 X1X, " ", DEC3 X3X, " ", DEC3 X2X]
SEROUT TX, LcdBaud, [LcdLine2, " ", DEC3 A1A, " ", DEC3 A3A, " ", DEC3 A2A]
RETURN
'NEW CODE BLOCKS************************************
Pot_SAWS: 'input pin 03 .. 10K TRIMPOT, .1uf cap and 220 ohm in series to
A1A = 0 'reset to 0
HIGH 3 'precharge the cap
PAUSE 100 '
RCTIME 3,1,A1A '
PAUSE 10 '
'debug "A1A is ",dec A1A,CR 'used to get real scale
A1A = A1A+0 ' Add to or change scale to get into the range needed
DEBUG "A1A is ",DEC A1A,CR '
PAUSE 100 '
A2A = A1A 'sets alarm for right saw the same as left
RETURN '
Pot_Xauger: 'input pin 04 .. 10K TRIMPOT, .1uf cap and 220 ohm in series to
A3A = 0 'reset to 0
HIGH 4 'precharge the cap
PAUSE 100 '
RCTIME 4,1,A3A '
PAUSE 10 '
'debug "A3A is ",dec A3A,CR 'used to get real scale
A3A = A3A+0 ' Add to or change scale to get into the range needed
DEBUG "A3A is ",DEC A3A,CR '
PAUSE 100 '
RETURN '
X1X_SPEED: 'get speed of left saw on pin 0
COUNT 0,500,X1X ' count pin 0 for 1/2 second
X1X = X1X*2 ' correct reading to full second
DEBUG "X1X IS ", DEC X1X,CR '
PAUSE 100 '
RETURN '
X2X_SPEED: 'get speed of left saw on pin 1
COUNT 1,500,X2X ' count pin 1 for 1/2 second
X2X = X2X*2 ' correct reading to full second
DEBUG "X2X IS ",DEC X2X,CR '
PAUSE 100 '
RETURN '
X3X_SPEED: 'get speed of left saw on pin 2
COUNT 2,500,X3X ' count pin 2 for 1/2 second
X3X = X3X*2 ' correct reading to full second
DEBUG "X3X IS ",DEC X3X,CR '
PAUSE 100 '
RETURN '
COMPARE: ' COMPARE SPEEDS TO ALARM SETPOINTS
ALARM = 0 '
IF X1X < A1A THEN X2 '
ALARM = ALARM +1 'FLAG TO SET ALARM IF ANY ARE BELOW SETPOINT
x2: '
IF X2X < A2A THEN X3 '
ALARM = ALARM +1 ' FLAG FOR ALARM
X3: '
IF X3X < A3A THEN Alarm_SET '
ALARM = ALARM +1 '
Alarm_SET: '
IF ALARM >0 THEN A_ON '
ALARM=0 'RESET ALARM FLAG
DEBUG "alarm off",CR '
LOW 5 'TURNS OFF BUZZER
LOW 6 'TURNS OFF LED
RETURN
A_ON: 'TURNS ON ALARMS & BUZZER
DEBUG "alarm on", CR '
HIGH 5 'turn on buzzer
HIGH 6 'TURN ON LED
PAUSE 100 'PAUSE LONG ENOUGH TO CHARGE CAP TO KEEP LED & BUZZER CONSTANT AND NOT INTERMITTENT
'ALARM=0 'RESET ALARM FLAG
'LOW 5 'TURNS OFF BUZZER
'LOW 6 'TURNS OFF LED
RETURN
'Z**********************************
Interesting...the code you had should have worked if you moved the LCD init code above Main. Replacing the GOTO with a LOOP should have caused a LOOP without DO error.
The LCD shouldn't do any blinking unless you are executing the following block of code repeatedly.
This code should only ever execute once. The Update_LCD routine is designed to overwrite the entire screen in such a way that you should never have to clear it and should not see any blink.
anyone ever see this happen. the top row gets three signals into the bs2, and displays the three speeds across top, the bottom row has three alarm setpoints that go with the speeds on the top row, and sound an alarm and led if the speed drops below the set point. this worked for about a day, now display shows this. and the center speed is no longer showing the speed of the signal.
i ran the signal speed of a mag pickup coil sensor thru a 220ohm resister then through, a In4004 diode with stripe facing sensor, then had a 4.7v zenier diode to ground and a 100k to +5v then straight into bs2. schematic below. lcd is 16x2 backlit serial connection
