Motor PWM signal, how far can it travel over the control cable?
My robot has several motors. So should I keep the motor drivers close to the Propeller and have long motor leads and short PWM cables?
Should I keep the Motor driver boards close to the motors and have long PWM and signal cables?
It dosent make a difference?
or am I think to much about this?
My bias would be to keep the drivers close to the motors (and the batteries close to them both) to minimize the high current high frequency cabling and start with twisted pairs for the signals making sure to not run them near the power cables and not in parallel with them for any distance. I'd get (borrow) a scope to look at the signals on the signal cables and shield any that look sloppy. If that doesn't help enough, I'd use some buffering at either end depending on what signals are being carried, how fast they have to switch, etc.
